Building Tips and technical articles. => Building techniques => Topic started by: Tim Wescott on December 09, 2011, 11:36:34 AM
Acetate window material seems to be fuel proof (or at least clear bubble-pack does, and I think it's the same stuff). And if I recall correctly, ABS plastic seems to be, too. (Ping-pong balls, unfortunately, aren't, as I discovered this weekend after whacking up a 1/2-A plane to use one as a fuel balloon holder).
Does anyone know what glues work well at sticking acetate to acetate, and acetate to wood, without getting unstuck because of the presence of nitro fuel? Will epoxy do it if I rough up the plastic?
Canopy glue such as RC56 will work, it will stand up to hot fuel, and fuel for a while, you may want to coat the canopy glue with epoxy after it has dried
I looked into ABS for fuel tanks. It appears to be soluble in nitro. Let me know if you find out otherwise. I have the technology to make really cool ABS tanks.
If it'll work on clear acetate, try that.
When I tested my ping-pong ball it was in a bit of clear bubble-pack; the bubble-pack wasn't marked while the ping-pong ball was well on the way to being dissolved.
Or if you rough it up and clean it well, YOu could use the slower JB Weld, I have several CF tanks that are put together with similar epoxy and they last several years. The fuel take a long time to soften the filled epoxy. I have tried high temp epoxy with ceramic powder filler and that also stands up well to fuel in raw state.
If it is not too thin you can try welding it.
I did this with my ABS wind shield on my motor bike.
Greetings Robert-Jan
