  • August 02, 2025, 05:40:13 AM
Author Topic: A question about using stencils for painting  (Read 2297 times)
Offline frank carlisle
« on: February 14, 2007, 01:50:38 PM »
I've been getting stencils cut on painters mask at the local sign shop and when I place them on the plane I've got to get them dead nuts on the first try. Which is a nightmare cuz they stick pretty good.   y1
My question is this------is there an agent that can be applied to the plane that will allow the stencil to be slid around till it's in just the right spot?  ???
Frank Carlisle
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: A question about using stencils for painting
« Reply #1 on: February 14, 2007, 03:52:58 PM »
Is that like film trim, Frank?  It has the stickum on the back?  If so, you oughtta be able to use the windex trick.
--Ray
--Ray
AMA902472
« Reply #2 on: February 14, 2007, 04:40:57 PM »
--Ray
After the stencil is in place I'm going to spray dope on it. Will the Windex hurt the dope?
Frank Carlisle
Online RC Storick
« Reply #3 on: February 14, 2007, 05:06:19 PM »
There is a process for putting stencils on. Leave the backing on-position stencil-tape at the bottom to get it registered- Fold down-remove backing -then roll the stencil up onto the airplane.
I can show you better than I can explain't it, I could show you but I am not ready to paint yet.. S?P
« Last Edit: February 14, 2007, 07:14:59 PM by Robert Storick »
« Reply #4 on: February 14, 2007, 05:58:22 PM »
Spaarky.........you are just the fellow I was hoping to hear from.
I understand what you are saying.......Position-Tape- Peel- Roll on from tape.  Right? Right.
Thankyou. H^^
Frank Carlisle
« Reply #5 on: February 14, 2007, 06:07:41 PM »
Do that on signs all the time, just like sparky says, use masking tape as a hinge to hold the stencil in place, hinge it back and remove the backing then stick her down
« Reply #6 on: February 14, 2007, 07:00:11 PM »
Got it. I had been told by different folks to use water, soapy water or some kind of solution, but that didn't sound right. I have stencils to paint tomorrow and I'm doing it the way you guys said.
Thank you very very much much.
Frank Carlisle
Offline Mike Foley
« Reply #7 on: February 14, 2007, 09:31:24 PM »
  Speaking of stencils, where do you get the small nomenclatures made. Things like No Step, Experimental, blah, blah blah
« Reply #8 on: February 14, 2007, 09:54:50 PM »
http://www.tanks-hangar.com/index.html
Try this link Mike and click on stencils. He must use an acid etch or some type of photo process to make them that small. I know of Tanks because I saw it in one of Sparky's posts.
Frank Carlisle
Offline Dick Fowler
« Reply #9 on: February 15, 2007, 06:11:38 AM »
My guess would be laser cut.
Dick Fowler AMA 144077
Kent, OH
« Reply #10 on: February 15, 2007, 01:46:33 PM »
I applied a stencil today using the method described by Sparky in this thread. It works slick as a whistle. Thankyou Sparky.
Frank Carlisle
Offline Rudy Taube
  • Ret Flyboy
« Reply #11 on: February 19, 2007, 12:08:46 AM »
Frank,
Thanks for asking this question. ..... I always wondered how it was done. (Thanks sparky :-).
That sure is a great looking twin. We are all looking forward to the video of your 1st flight.
Rudy
AMA 1667
