  • August 02, 2025, 05:43:09 AM
Author Topic: Plasticizer?  (Read 1820 times)
Offline the original Steve Smith
  • Fly Stunt!
Plasticizer?
« on: February 17, 2007, 10:15:29 AM »
I have seen the concept of plasticizer mentioned in some finishing articles and I have a few questions.
Why use plasticizer in dope?  I assume it makes the covering less brittle and more flexible.
I am planning on using silkspan on a Ringmaster - is plasticizer a good thing on silkspan covering?
I think Brodak has a product but I also recall someone using something more common but I cannot remember what it is.  It seems that a few drops was all it took.   S?P
Anyone have any experience good or bad with the concept and actual use?
AMA 2112
Online RC Storick
Re: Plasticizer?
« Reply #1 on: February 17, 2007, 10:54:28 AM »
Easy plasticizer is 1 drop of Castor oil per ounce of dope. Less cracking. You can also use flex-all available at the paint store for rubber bumpers.
Offline Robert W
Re: Plasticizer?
« Reply #2 on: February 18, 2007, 07:37:17 AM »
Is that one drop per unthinned or thinned ounce of dope? The second question would be does this also reduce the amount of shrinkage?
AMA 28627
Online RC Storick
Re: Plasticizer?
« Reply #3 on: February 18, 2007, 07:52:40 AM »
Add Castor before thinning. Yes it reduces shrinking some.
Offline Jim Oliver
Re: Plasticizer?
« Reply #4 on: February 18, 2007, 08:38:39 AM »
Hi,
I have used Sig Lite Coat clear and found it to have different sanding characteristics than Sig Super Coat clear.  Also, Super Coat clear with Dave Brown's "Flex All" added ( about half of what the instructions suggest) also have different sanding properities.
The Lite Coat and Super Coat with "Flex All' added wanted to roll up under the paper when I tried to dry sand them; wet sanding is OK, however.
As usual, YMMV!
Jim
Jim Oliver
AMA 18475
Re: Plasticizer?
« Reply #5 on: February 18, 2007, 10:24:33 PM »
Hi,
As usual, YMMV!
Jim
Hi Jim,
The Flex All seems to extend the curing time of clear dope.  That is the rationale I came up with when i got the bubble gum bits when sanding.  it went away later when the dope had dried longer...........
Bill <><
