  • June 19, 2025, 03:51:22 AM
Author Topic: sticky  (Read 1054 times)
Offline roger
sticky
« on: January 27, 2007, 09:31:34 PM »
hi
my question is: when applying pin striping, or water type rondells on a wing or fuse. what dose one use to hold all that mass down? and so it wont wringle it or the striping. i notice the edges are already getting... ??? ???
roger and out.
Offline Rob Killick
Re: sticky
« Reply #1 on: January 28, 2007, 11:24:08 AM »
Hi Roger ,
If you're using water-slide transfers (decals) , try some Micro Set and Micro Solve to snuggle the decals down .
I use this stuff on plastic scale models .
Test it on a dopped piece of scrap balsa , using some of the clear carrier film from the decal sheet 1st .
I'm not sure if the water transfers you are using from the kit are the same formula as the plastic kit decals , so TEST , TEST , TEST !!
Good luck :)
Rob Killick
Rob Killick , MAAC 33300
