  • July 01, 2025, 05:45:31 PM
Author Topic: Prop for .36  (Read 5117 times)
Online James Mills
Prop for .36
« on: June 15, 2010, 08:00:44 PM »
Randy,
What prop should I start with on a Magnum 36 (the prop listed on your site designed by Werwage or can I cut a 11 to 11.5 carbon down)?
James
AMA 491167
Re: Prop for .36
« Reply #1 on: June 16, 2010, 11:32:31 AM »
Randy,
James
You can run either one, they both will work, The simplest maybe to just use the 10.6 x 4.9 wide CF
Online James Mills
Re: Prop for .36
« Reply #2 on: June 16, 2010, 07:46:00 PM »
Do you have the 10.6 X 4.9 in stock?
James
AMA 491167
Re: Prop for .36
« Reply #3 on: June 17, 2010, 09:08:06 AM »
James
Yes
