Vendors Corner => Aero Products => Topic started by: James Mills on June 15, 2010, 08:00:44 PM
Randy,
What prop should I start with on a Magnum 36 (the prop listed on your site designed by Werwage or can I cut a 11 to 11.5 carbon down)?
James
Randy,
James
You can run either one, they both will work, The simplest maybe to just use the 10.6 x 4.9 wide CF
Do you have the 10.6 X 4.9 in stock?
James
James
Yes
