  • July 11, 2025, 01:24:01 PM
Author Topic: PA engine mount patterns  (Read 11373 times)
Offline Allan Perret
  • Proverbs
« on: April 01, 2009, 07:34:18 AM »
Randy:
Which engines in your PA line up share the same crankcase / mount pattern ?
Allan Perret
AMA 302406
Slidell, Louisiana
Re: PA engine mount patterns
« Reply #1 on: April 02, 2009, 09:02:40 AM »
Randy:
Hi Allan
The PA 40 Merlin has the same bolt pattern as a ST46, although it is longer,lighter,(8 ounces)more power
The Standard 40 ,51,61,65  are the same bolt pattern as the OS 40-46 SF and the OS VF
The new Merlin 75 has the same bolt pattern as a ST60
  • Proverbs
« Reply #2 on: April 03, 2009, 07:26:20 AM »
Randy, or  anybody:
Do you have any drawing files available for your PA engines ?
Allan Perret
AMA 302406
Slidell, Louisiana
« Reply #3 on: April 04, 2009, 01:14:39 PM »
Randy, or  anybody:
Yes I can print off  3 view of the engines for you
  • Proverbs
« Reply #4 on: April 04, 2009, 05:42:34 PM »
I would like the drawings for the Ultra 40 and the reg 40,51,61,65 series.
Allan Perret
AMA 302406
Slidell, Louisiana
Offline Matt Colan
« Reply #5 on: April 13, 2009, 11:29:22 AM »
Hi Allan
Randy, how much longer is the Ultralite PA 40 than the ST 46?
« Reply #6 on: April 14, 2009, 01:55:15 PM »
Hope you can read this, it has the sizes on the drawing
Offline Matt Colan
« Reply #7 on: April 14, 2009, 02:26:17 PM »
Yes I can Randy.  That is just what I needed.  Thanks H^^
Offline Peter Ferguson
« Reply #8 on: October 20, 2009, 08:16:20 PM »
Randy, Are these engines direct drop ins for the VF or is there a difference in case length. I'm particularly interested in the PA 65.  regards , Peter
Peter Ferguson
Auburn, WA
« Reply #9 on: October 21, 2009, 10:05:41 PM »
They are exact drop in with the exception of the needle
