  • June 21, 2025, 03:53:21 PM
Author Topic: Thunder Tiger 36 Conversion to Aero Tiger 36  (Read 10014 times)
Offline Mike Foley
« on: March 24, 2008, 01:10:40 PM »
Randy,
Will you accept a customers NIB Thunder Tiger 36 RC and convert it to the Aero Tiger 36 stunt? If so how much do you charge, and do you include a muffler?
Thanks D>K
Re: Thunder Tiger 36 Conversion to Aero Tiger 36
« Reply #1 on: March 25, 2008, 09:16:56 AM »
Randy,
Thanks D>K
Hi
Yes if your engine is new the cost is 140.oo, I sell  cnc light  tongue mufflers 18.95 and  ultra light  cnc  tube mufflers  38.95
Offline Greg Howie
« Reply #2 on: October 18, 2009, 09:34:32 PM »
Yeah me too Randy . Do you think the tongue muffler makes the engine run hotter ? What dose the tube weight ? dose it come with a muffler pressure tap ?
Oh ....I see ,you mean the ones on a string ?
Greg Howie
« Reply #3 on: October 19, 2009, 11:28:59 AM »
Hi Greg
No the tongue mufflers does not make the motor hotter, running the needle in a lean setting makes the motor hotter, or stuffing up the holes with screws
The cnc light tube weigh approx 1 ounce, it does not come with pressure fitting and I recomend using it without pressure
Offline Greg Howie
« Reply #4 on: October 21, 2009, 12:15:01 AM »
how do you make it not go rich in to the wind then lean down wind with out presure ?
Greg Howie
« Reply #5 on: October 21, 2009, 10:04:25 PM »
I do it with a 90 degree angle on the end of the uniflow vent, You turn it up down or to the side, it does not face into the wind
