Link 1
Stunt Hangar YouTube
P.A.M.P.A.
AMA
Balsa Density Calculator
This topic
This board
Entire forum
Google
Home
Help
Tags
Advertise
Login
Register
July 31, 2025, 06:53:49 PM
1 Hour
1 Day
1 Week
1 Month
Forever
stunthanger.com
Vendors Corner
Aero Products
(Moderator:
RandySmith
Moisture Damage
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Moisture Damage (Read 15912 times)
afml
25 supporter
Trade Count:
0
Captain
Moisture Damage
on:
August 12, 2019, 06:29:07 PM »
Hi Randy,
Was assisting a fellow club member's Widow so she can downsize and move. Her husband had some motors in the original boxes that had (unbeknownst to anyone) absorbed some moisture and the cases have acquired a chalky exterior. Is there any safe way to restore these so they can be sold to financially assist her in moving on to a new location.
Many thanks in advance for your time and valuable information!
"Tight Lines!"
Wes
Logged
Wes Eakin
25 supporter
Trade Count:
0
Admiral
Re: Moisture Damage
Reply #1 on:
August 14, 2019, 08:52:51 PM »
Hi Wes;
Just saw this, and was going to suggest a stiff bristle brush of some kind and some light oil combined with some elbow grease. I have seen this before and as long as the internals are OK, it won't bother the external surfaces much. The heavy brush will knock off the white stuff and the cast aluminum will absorb some of the oil. When you have done the whole engine, wipe it off with a clean rag and see how it looks. This should leave behind a light coating of oil also. Then wrap in a fresh baggy for further storage.
Logged
EAA 1038824
RandySmith
Administrator
Trade Count:
0
Admiral
Welcome to the Stunt Hanger.
Re: Moisture Damage
Reply #2 on:
August 20, 2019, 12:43:26 PM »
Hi Wes what Dan said, BUT I would be leary about the insides, most engines that have this much corrosion also has damage inside, so
look there too , after they are cleaned and oiled, put them in zip lock baggies
Logged
afml
25 supporter
Trade Count:
0
Captain
Re: Moisture Damage
Reply #3 on:
August 20, 2019, 02:19:23 PM »
Many thanks for the replies!
Will follow up with the provided suggestions.
"Tight Lines!"
Wes
Logged
Wes Eakin
Print
Pages: [
1
Go Up
« previous
next »
stunthanger.com
Vendors Corner
Aero Products
(Moderator:
RandySmith
Moisture Damage
