  • August 01, 2025, 03:08:49 AM
Author Topic: Carbon Gear & wheel Pants  (Read 12242 times)
Offline Mike Clark
  • Lets get together and burn some fuel!
  • ACE
« on: April 16, 2007, 08:02:18 PM »
Hi Randy,
I am building an SV11 type aircraft and it's time for the gear. What carbon gear & wheel pants do you reccommend?
The plane will be powered by a T&L ST60. I am sure that the prop length will play into the gear height
so what size 3 blade prop should I use, 12/4N?
Mike Clark
Mike Clark
Re: Carbon Gear & wheel Pants
« Reply #1 on: April 17, 2007, 10:52:57 AM »
HI Mike
The  60 cf gear I have with the Bolly glass  or  carbon pants  will work and  look great  www.aeroproduct.net
As to the 3 blade prop with a  ST 60  most use the  12 x 6.5n  Bolly,  Jim Casale  used this exact combo
