  • August 01, 2025, 06:56:51 PM
Author Topic: Tongue muffler for Brodak 40  (Read 13937 times)
Offline Mike Foley
« on: April 17, 2007, 12:59:54 PM »
  Recently purchased your tongue muffler from Brodaqk for the Brodak 40.  Muffler fits the motor perfectly however the mounting bolts do not line up. Off by approximately 1/16 to 1/8.  Obviously the muffler mounting holes need enlarging.  What is the proper way to do this?
Thanks!
Re: Tongue muffler for Brodak 40
« Reply #1 on: April 18, 2007, 12:05:53 PM »
Thanks!
Hi Mike
The way to enlarge holes is with a larger drill bit, or a reamer
I just went and measured a Brodak 40 it is 1.115 inches, my muffler bolt spacing is 1.115 inches, all of them I looked at were the same, However the muffler was  made  to fit the HP 40   FSR 40-45 and some of the FOX 40s  so opening up the holes  slightly is no problem. If you do have a muffler that is off by 1/8 inch I would like to see it. If you  feel that it is a big problem you can ship it back to Brodak or to me
REgards
Offline Mike Foley
« Reply #2 on: April 18, 2007, 08:59:11 PM »
  Thanks for the reply Randy.  The bolt spacing is maybe off by 1/32" after looking closer with my glasses on. No biggy, I will drill it out slightly and it will be fine. I will say very nice quality and feather light.
Thanks!
