  • June 17, 2025, 04:53:59 AM
Author Topic: Plastic or Nylon?  (Read 993 times)
Offline Dennis Saydak
Plastic or Nylon?
« on: January 23, 2011, 05:27:47 PM »
I have a TD .020 that is virtually new but it is frozen up. I'm wondering what the best way to free it up is. I don't want to use anything that will damage the red crankcase housing or tank.
Offline George
  • Love people, Use things.
Re: Plastic or Nylon?
« Reply #1 on: January 23, 2011, 06:44:29 PM »
I'd remove the plug and tank, then immerse it in fuel for a couple of minutes...assuming it's frozen with congealed castor oil.
George
George Bain
AMA 23454
Offline Dennis_Langworthy
« Reply #2 on: January 24, 2011, 06:11:31 AM »
mount a prop and use a hair drier to get the cylinder warm .  After you can turn it over, take it apart and clean it out.  I use denature alcohol and have never had a problem with the anodizing.  I use a brass pistol cleaning brush for cleaning the cylinder and a small wire tooth brush for the rest.
