  • July 08, 2025, 01:19:38 PM
Author Topic: what line length?  (Read 1831 times)
  • Gravitywell
what line length?
« on: September 01, 2011, 06:46:55 PM »
I am building a White Lightning by Bruce Feaver and am putting a Brodak .061 on it.  My question is, what line length should I use?  I have a set of .008x52' braided lines....are they too long? H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline ray copeland
Re: what line length?
« Reply #1 on: September 01, 2011, 08:17:30 PM »
Glenn, your question is basically how powerful is the brodak .061. I am not qualified to comment on that. But, my slightly oversized White Lightning flies very well for a flat winger with a norvel .061 on 45 foot 30lb. spiderwire lines.  The .008 braided lines were just too much of a hassle for me.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #2 on: September 01, 2011, 09:43:38 PM »
I fly most all my .061-powered planes on 48' of Spiderwire.  I do fly my combat wings with .061s on 42', just for the adrenalin rush.  Lap times, and perception, is about equivalent to 120-mph Fast ships on 60' lines.  Mind, these are Norvels and one Wasp.  Don't know how the Brodak compares.
--Ray
AMA902472
Offline Larry Renger
« Reply #3 on: September 01, 2011, 09:45:42 PM »
I would try the 52' lines with a great deal of caution.  I think 45' is about right, or even a bit long.  However, it is easier to cut lines down, than add to them.... :##
If you fly conservatively, you should be able to safely cut them down a bit at a time until the plane flies solidly at the ends no matter what the maneuver.
  • Gravitywell
« Reply #4 on: September 01, 2011, 10:54:20 PM »
OK....I'll fly the plane on 52' and cut them down as needed.  Thanks fellas.  Now for something else....what wing tip weight?  One nickle or two? ;D
Glenn Reach
Westlock, Alberta
« Reply #5 on: September 02, 2011, 08:45:12 AM »
On sheet wings, I put a bolt through the wing and just add or subtract washers as needed.
    • Minnesotamodeler
« Reply #6 on: September 02, 2011, 03:28:19 PM »
One nickel oughtta do.  I use a penny on smaller .049 models.
--Ray
AMA902472
Offline Wayne Collier
« Reply #7 on: September 14, 2011, 12:23:14 PM »
        Why waste a nickle when you can get a good washer for only 7 cents (plus tax).   :-\
