  • June 17, 2025, 05:31:37 PM
Author Topic: mouse racer  (Read 2058 times)
Offline frank j. scire
mouse racer
« on: January 09, 2011, 08:35:22 PM »
Hey guys,I would like to start building from scratch.Can any one help me with dimenions or plans for a .049 mouse racer.They seem prety strait forward and a good way to get started. thanx for any help.
Offline kenneth cook
Re: mouse racer
« Reply #1 on: January 10, 2011, 02:12:03 PM »
       Frank, are you looking for one to accept a Tee Dee? I recently built two. My first one was a Midwest Kit in which I think I still saved the plans. I will have to look but I'm pretty sure I saved all of the wood after all the die cut pieces were removed. I figured this way, I could just easily replicate broken pieces. That particular one is going on a year old. I learned one very important lesson. I found that basswood becomes a very practical substitute over balsa. These planes take a beating. I diced the wing in half on both of my models and glued in a spruce spar. I found this very important as it prevents the shedding of parts on bad landings and take offs. My initial flight resulted in the plane rolling in and climbing straight up and over my sons head I think you know the rest of the story. Someone on here posted sometime back a very cool looking mouser which used a arrowshaft body. It was well engineered. I will search for the box tonight and try and find it. The other I built was basically scratch built. I got the idea from a post in the speed section here. Ken
Offline Balsa Butcher
  • High Desert Flier
Re: mouse racer
« Reply #2 on: January 10, 2011, 05:59:19 PM »
If you are looking for a beginner's Mouse Racer for the Cox Reed Valve engines (Black Widow etc.) check out the WAM (Western Association of Modelers) Mouse Racer. Free plans are available at Heman Lee's "Aeromaniacs" web site. Don't let the simplicity fool you, I have seen them race and they are pretty darn fast. The AMA plan service also lists a number of mouse racers. I have built the "Annie" mouse (plans available from AMA.) It is fast but has a small wing and is a little harder to catch and pit than longer winged racers (such as the WAM racer). 8)
Pete Cunha
Sacramento CA.
AMA 57499
Offline Larry Renger
Re: mouse racer
« Reply #3 on: January 10, 2011, 06:09:55 PM »
Also do a search on "Venom" to get the skinney on how to build a killer motor!  VD~  An actual Venom is totally competitive, but who needs to spend $300?  Buy the correct parts, and you can do as well.
Offline Dave Rolley
Re: mouse racer
« Reply #4 on: January 10, 2011, 08:13:50 PM »
Give Melvin a call at:
MBS Model Supply
P.O. Box 282
Auburn, KS 66402-0282
Phone: (785)256-2583 Cell: (785)221-7042
http://www.mbsmodelsupply.com/index.php
It isn't listed on his web site, but every once in a while he has a run of Streaker Mouse Racer kits made up.
Offline don Burke
Re: mouse racer
« Reply #5 on: January 10, 2011, 08:14:59 PM »
Or found this with a web search.
Bear Hobbys
1217 S. Phoenix #38
Ft. Smith, Arkansas 72901
E-mail: BEARhobbys@aol.com
don Burke AMA 843
Menifee, CA
