  • June 18, 2025, 07:50:14 AM
Author Topic: 1/2a Dragon Fire  (Read 3786 times)
Offline bob werle
1/2a Dragon Fire
« on: March 05, 2010, 02:40:35 PM »
Here is a photo of a profile 1/2a called Drgon Fire.  It frim plans from an english model mag.  They said it was indusreuctable.  The top motor mount runs the full lenght of the fuse.
ama 5871
Offline John Castle
  • The Bent Pin
Re: 1/2a Dragon Fire
« Reply #1 on: March 05, 2010, 03:03:31 PM »
They said it was indestructible.  The top motor mount runs the full length of the fuse.
Hmmm, I may need one of those... ;D
John Castle
McMinnville, Oregon
AMA# 589650
Offline Augsburger
  • Augsburger
« Reply #2 on: March 05, 2010, 10:27:46 PM »
me too...  looks tough...  very cool wing
Wilder Eber
Offline John Crocker
« Reply #3 on: March 06, 2010, 09:03:50 AM »
I'd put money on it I could destroy it.  Matter of fact, I guarandamntee it.  Lemme fly it, it'll look like this in one flight and I won even have to work at it!
« Reply #4 on: March 06, 2010, 10:11:24 AM »
Pictures tell the tale.  I have yet to find a plane that was not indestructable.  Even the old Guillows Rat Racer had to be put back together a couple of times.   H^^
PS: The plane looks good. jeh #^
Offline bob werle
« Reply #5 on: March 06, 2010, 01:35:43 PM »
here is a copy of the plans.  I hope they are the right size
ama 5871
Offline Robert McHam
« Reply #6 on: March 06, 2010, 05:46:14 PM »
Bob, thanks for posting. I had a feeling this would be something folks would like.
I have been studying the plan as it is quite different than most go in design.
I am not sure I understand how the LE and center wing sheeting is suppose to fit exactly. It looks like the covering would be raised above the ribs. Not what I would expect but that might be how it goes.
Robert
Offline bob werle
« Reply #7 on: March 06, 2010, 06:04:15 PM »
The basic wing is a flat balsa plank with openings cut out on esach side and 1/2 ribs glued top and botton of the plank.  The ribs are split front and back of the spar (1 ea top and bottom)  The wing builds quite light and solid.  The bellcrank is mounted external on the ply section top and bottom.  I hope this explains it.
ama 5871
Offline don Burke
« Reply #8 on: March 06, 2010, 08:14:04 PM »
I think in the politically correct, non-committal, world "indestructable" has been replaced with "damage resistant".
Didn't the old adage go.....
"Give me a lever long enough and a place to stand, and I will CRUSH the fulcrum!"
don Burke AMA 843
Menifee, CA
« Reply #9 on: March 07, 2010, 07:20:51 AM »
I like it and tried to print a copy.  Only get left half of page.  It remeinds of the construction of the old Omega combat ships, 1/2A and full size.  I can see the construction is for trying to get a flat wing without warps.  The center sheet is made first and nailed/pinned to the building surface.  Put all the top surface on and flip it over and do the bottom.  If you don't like diamond airfoil, the rib leading edge can be airfoiled when you cut the ribs.  Should fly well as it is. H^^
Offline John Castle
  • The Bent Pin
« Reply #10 on: March 07, 2010, 09:42:31 AM »
So if I wanted to scale this for a .15 sized plane what sized wingspan should I use. It appears to have a 20" span now.
John Castle
McMinnville, Oregon
AMA# 589650
« Reply #11 on: March 07, 2010, 11:53:32 AM »
Thanks I do understand the primary part of the wing build and I can see now how my choice of words was ambiguous.
My question refers to the top and bottom sheeting covering the 4 most inboard ribs once the top and bottom rib halves and the bell crank plywood is in place. I suppose it really isn't of much consequence if the sheeting lifts the covering higher than the ribs in the center.
Robert
Offline bob werle
« Reply #12 on: March 07, 2010, 12:11:51 PM »
I made the center ribs smaller than the rest so the center scetion was the same hight as the rest
ama 5871
Offline bob werle
« Reply #13 on: March 07, 2010, 12:18:12 PM »
As far as the .15 size, this all started when I started uo up size a 1/2a White Lightning for a .19.  That took a 145%.  Most .15 size kits are around 38 to 41" span.  This particular model was actually a test of the wing construction.  If it was easy I could use it on a sport scale with a different wing shape.  Just cut the plank to shape and add ribs.
ama 5871
