  • July 16, 2025, 01:14:34 AM
Author Topic: Old Tee Dee engine mount needed.  (Read 1920 times)
« on: February 20, 2013, 10:15:25 AM »
Is anybody holding a Kirn Kraft or Custom Craftmanship screw-in mount they want to part with?
How about a red plastic tank mount?
I'm trying to put together a matched pair for a twin.
Offline ray copeland
Re: Old Tee Dee engine mount needed.
« Reply #1 on: February 20, 2013, 10:24:41 AM »
Paul, i am fairly sure i have a red engine/tank mount i don't need. I will check when i get home this evening. Ray
« Reply #2 on: February 20, 2013, 03:28:33 PM »
Paul, i do have one , pm me with your address if you need it.
Offline Reptoid
« Reply #3 on: February 22, 2013, 05:40:17 PM »
If you want to go with the aluminum radial mount you can get them here:  :)
http://www.texastimers.com/
       Don
       AMA # 3882
« Reply #4 on: February 23, 2013, 02:49:37 PM »
Thanks.
I was looking for the current source.
Offline Michael Alurac
  • AMA 63056 kotrc.org2013-2014 & 2020 President
« Reply #5 on: February 27, 2013, 10:33:17 PM »
Reptoid,
Thanks for the awesome suggestion/link to Texas Timers. They've got the goods!
« Reply #6 on: February 28, 2013, 09:16:11 AM »
Ray,
Thank you very much.  I received the tank today.  Now I have a par to work with.
« Reply #7 on: February 28, 2013, 09:21:47 AM »
Can you stunt those red tanks or do they just feed off the bottom?
There' certainly not "full stunt".  But I might be able to do an outside loop, lazy eight, and a lap or two inverted if it do 'em early in the flight.  The tanks are pretty big for a 1/2A so I'll have some time before the pickup position becomes a factor.
On a 1/2 A scale job they're a lot handier than making a tank and finding a place to put it.
Offline Larry Renger
« Reply #8 on: April 25, 2013, 10:14:57 PM »
An excellent question for which I never got an answer. Also with stunt venting why is the pickup in the wrong place?
