  • June 19, 2025, 12:54:28 AM
Author Topic: Off the wall thought here...  (Read 1370 times)
Offline jim gilmore
« on: October 17, 2011, 01:57:39 AM »
I often look over the items that are sold throught hobby king and They have a model I think might make an interesting project.
Its a a10 with edfs and while this is a rather small model. I'm wonderng if it would work as a 1/2A control line project.
Anybody here have any cluse on these small ducted fan models and just what Kind of power they may have ??
Re: Off the wall thought here...
« Reply #1 on: October 17, 2011, 08:14:25 AM »
I beleive it comes with the electric ducted fan motors installed.   Get Clancy's electric set up and go for it.  I have even thought of it myself for control line fun scale. H^^
Offline Larry Renger
« Reply #2 on: October 17, 2011, 11:06:39 AM »
I did a search on "Clancy" and got nothing.  What are you referring to?
« Reply #3 on: October 17, 2011, 11:40:01 AM »
This guy:
http://stunthanger.com/smf/index.php?board=39.0
Ducted fan engines tend to be "constant thrust" devices.  Where a prop will give you more thrust at low speeds (and load the motor down), a ducted fan won't.  Put a big enough prop on something, at a low enough pitch, and it'll be very like a "constant speed" device -- which is nice for CLPA.  You won't get that from a ducted fan.
So I suspect that you'll want a really smooth (probably paved) surface to take off from, and you'll want to expect a long takeoff roll.  Once you get airborne, assuming enough power, it should go like a bat out of Hell.  Why the bats in Michigan's upper peninsula are so fast -- I dunno.  I'm just repeating the cliché: http://en.wikipedia.org/wiki/Hell,_Michigan.
Offline john vlna
« Reply #4 on: October 17, 2011, 05:51:52 PM »
I use the universal handle concept on models from 1/2A to .60 size. The concept is described here http://stunthanger.com/smf/index.php?topic=15377.0
My handle is an electified version of the classic 3-line handle. All the U/tronics components, including a battery are in the handle.
« Reply #5 on: October 18, 2011, 09:02:29 AM »
Clancy's U-Tronic controls in the vendor section. H^^
« Reply #6 on: October 19, 2011, 09:11:46 AM »
Many garcias, senior.  ;D
