  • August 01, 2025, 08:22:11 PM
Author Topic: Line length  (Read 1725 times)
Offline Bootlegger
Line length
« on: June 28, 2020, 01:41:41 PM »
 Guy's I am gonna build a Sky Ray 1/2A  for our half " A "  day and I want to use power pro 20# test lines in 40' length using a Cox .049 Baby B engine, will this work and if not please advise and suggest..  Thanks
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Line length
« Reply #1 on: June 28, 2020, 03:05:18 PM »
40' might be a bit much for a Baby Bee.  Back in the day I flew all of mine on 25-30'
Offline Fredvon4
  • Central Texas
Re: Line length
« Reply #2 on: June 29, 2020, 08:06:02 AM »
good plane...week engine (typically)....old guy I highly recommend a Medallion with screw in back plate Radial mount and simple balloon tank
line length dictated by plane weight, engine authority, prop, line drag*, and local winds
long draggy lines will turn a light under-powered plane into the circle
Fred von Gortler IV
Offline Al Ferraro
Re: Line length
« Reply #3 on: July 03, 2020, 09:09:41 PM »
 I fly my 1/2a on 48, lines.
Al
Offline Bootlegger
Re: Line length
« Reply #4 on: July 04, 2020, 06:33:44 AM »
 Al, could I get some more info such as power plant,model weight and specs, as well as other info that you will share, and thanks...and line size..
Gil Causey
AMA# 6964
Offline Al Ferraro
Re: Line length
« Reply #5 on: July 05, 2020, 07:18:06 AM »
     My model weight is 13 oz, prop is a APC 6x3 or 6x2, engine is a Norvel .061, stock head, using a bladder tank. The lines are 48' .008 7 strand. l flew it at Brodak last year but scratched out of the contest when it was my turn to fly, winds pick up over 35mph.
Al
Re: Line length
« Reply #6 on: July 07, 2020, 03:32:02 PM »
Legs-in-boots,
Another data point:
SIG Baby Skyray with added gussets along wing joint (upper surface) and stab. Added landing gear (1/16" wire) and one inch Williams Bros wheels. Rubber tires, not foam. Monokote on wings, stab and elevators. KlassKote on the rest.
Cox product engine (twin port with the dual slit exhaust), standard glowhead, Baby Bee tank. No mods, no hop-ups. Mounted upright.
Weight is 184 gm (6.5 oz.) less propeller. That includes a whopping big fender washer (1-1/2" diameter) for tip weight, as I use the plane for ab initio training of kids I drag out of the parking lot.
I fly it on .008x42' lines using a Renger/RSM 1/2A handle that works well. The long lines are good for slower rotation for beginners. It will wingover and loop if not too breezy. It will fly mostly straight and level in a pretty good breeze with this combination. I might take a couple feet off the lines and reduce the tipweight if I was trying to do much stunting.
I think your choice of 20 lb test Spectra is a good one.
My Skyray has had a LOT of beginner flights, and is still capable....
Good luck with yours!
McDivot
