  • June 17, 2025, 07:27:11 AM
Author Topic: blank  (Read 1634 times)
blank
« on: April 29, 2013, 08:55:45 AM »
blank
« Last Edit: September 07, 2021, 08:21:27 PM by Motorman »
Online Dan Berry
Re: Tatone Mount for Cox TD .049
« Reply #1 on: April 30, 2013, 07:41:22 AM »
Mount with a tank?
Online Dan Berry
« Reply #2 on: May 02, 2013, 11:15:43 AM »
Ah. I don't have that.
Are you familiar with backplate mounts? The are still available and weigh less.
Online Dan Berry
« Reply #3 on: May 02, 2013, 05:23:04 PM »
I've seen a lot of backplate mounts on FF planes and never saw one that was a problem.
A tiny drop of soft Loctite could ease concern.
Online Dan Berry
« Reply #4 on: May 05, 2013, 01:42:54 PM »
Hank Nysrom at Texas Timers.
should be
Texastimers dot com
He also has the fine-thread needle valves that make needling a TD easier.
Offline Reptoid
« Reply #5 on: May 05, 2013, 04:59:38 PM »
I believe this is the only one for beam to radial for 1/2A that's still in production:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXB866&P=7
       Don
       AMA # 3882
