  • July 02, 2025, 10:20:08 PM
Author Topic: New concept 1/2A handle  (Read 1689 times)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« on: August 23, 2007, 08:01:33 PM »
OK here's another of my current projects while housebound: It's an idea I've been mulling around on for some time now.  Same principle as my old handle, line reel incorporated into the handle.
What's the new concept, you say?  Two reels, NOT one for each line, but to enable winding up the lines in a figure-eight pattern.  Eliminates the "one-twist-per-revolution" that happens with a standard single reel if you try winding up the lines hand over hand rather than turning the reel itself.  With the figure eight concept, you can indeed wrap up the lines hand over hand, keeping the handle in one position, since the twist around one reel is negated by the opposite twist around the other.  Much faster, also reels out very smooth and fast.
I've only tried it so far with Spiderwire; i intend to try next with .008 steel lines to see if the radius of the reels is large enough to keep the lines from curling.
--Ray
--Ray
AMA902472
Offline Robert McHam
Re: New concept 1/2A handle
« Reply #1 on: August 23, 2007, 09:34:28 PM »
That is a fine handle and well thought out.
I want one in metallic green trimmed in gold.
Robert
    • Minnesotamodeler
« Reply #2 on: August 24, 2007, 01:51:08 AM »
You want some pinstriping on it?  Or I could send you over to Frank Carlisle for some really cool stars...
--Ray
--Ray
AMA902472
