  • August 02, 2025, 05:26:33 AM
Author Topic: The force was not with me  (Read 1580 times)
Offline John Crocker
« on: April 20, 2008, 05:51:50 PM »
while flying at then inlaws today I lost the Mini Force to slack lines and a puff of wind on a wingover today.  Full speed with a 5x3.5 MA on 45' lines nosed in.  Fuse turned to toothpicks from the trailing edge to the stabilizer.  Not sure but looks like the engine housing around the venturi cracked (dangit!!!).  Wing sounds like a maracca, splinters coming through the covering.  Was able to salvage the stabilizer and elevator, can't believe they made it as they were "stick built" and covered.  Plane is a lost cause, time to start another.
Offline Bill Adair
  • AMA 182626
Re: The force was not with me
« Reply #1 on: April 20, 2008, 07:13:56 PM »
John,
Bummer!
Bad enough to lose a nice airplane, but damaging a good engine really hurts.  HB~>
Alan Hahn
« Reply #2 on: April 20, 2008, 08:19:10 PM »
Remember---a picture is worth a thousand words! :'(
« Reply #3 on: April 21, 2008, 09:55:44 AM »
J.B. Weld (the real stuff, not the *quick*) has always fixed a *crack* for me in that area.  Just clean it REAL good.  All you need there is a seal, if it is in the area around the venturi.
Bill <><
« Reply #4 on: April 21, 2008, 10:24:22 AM »
THANKS BILL!!!  I was wondering if good ole JB would help me out on this, gues I'll find out for certain
Offline Bill Adair
  • AMA 182626
« Reply #5 on: April 21, 2008, 01:09:30 PM »
John,
Hobby People has replacement parts for the Wasp, and crankcases are only $12.
http://www.hobbypeople.net/part/211280.asp
I noticed that their engine price went up to $50, while Tower still lists them for $45.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #6 on: April 21, 2008, 02:41:02 PM »
Bill is correct, I've repaired two Norvels with cracked cases, just clean it really well with alcohol and layer some on.  It's been holding a crack down the venturi for 2 or 3 years now, hasn't spread, also holding a venturi insert in on another.
--Ray
AMA902472
