  • June 16, 2025, 02:39:07 PM
Author Topic: First flight of Queen Bee  (Read 1178 times)
Online kenneth cook
« on: November 15, 2009, 04:10:43 PM »
  After a bit of tinkering with the .020 last night I screwed it on and went to the field today. Engine has been sitting for nearly 30 yrs now and I figured I replaced all the necessary items. What I didn't do was clean the metal backplate good enough especially where the pick up tube attaches. Well after nearly 20 frustrating minutes I took it apart and squirted fresh fuel through everything and went for the second attempt. It was a real success and quite a fun plane to fly as it got many of the other members attention or maybe it was just our laughing. The plane is quite maneuverable as we went right into the eights and inverted flight on the second attempt. The squares were fast but the wingovers were just cool. This plane is fast and a lot faster than what I thought it was going to be. It was my turn at the handle it it got away from me for more than 3/4 of a lap then I  got it stable again. The .020 was running like a charm as I left the needle right where it was at for all the flying today. The plane just makes you smile and did the same for the people passing by. I started the plane 2 years ago and put it on the backburner when I ran into a snafu in which everyone here helped me out with. I was building from a 8x11 xerox sheet which wasn't very clear on assembly. The bellcrank was a bit of a gray area and once I saw some of the photos, it was easily resolved. I covered the plane with jap tissue. I used purple on the fuse and yellow on the wings then some thinned coats of dope. Its a great looking plane. I look forward to flying it some more and I highly recommend it to anyone looking to venture into .020 flying. Ken
Offline Thomas Wilk
    • Tom Wilk's old mag plans on CD
Re: First flight of Queen Bee
« Reply #1 on: November 23, 2009, 01:05:02 PM »
Larry Scrinzi's biography is on the net.  just type Larry Scrinzi and you'll get a number of hits.  Larry still flys at VSC  and attends the Nats.  My sons and met Larry in NJ in the 1960's.
Tom Wilk
Offline George
  • Love people, Use things.
« Reply #2 on: November 23, 2009, 07:27:06 PM »
Tom,
I think you mean Larry Scarinzi. Here's the link to his autobiography:
     http://www.modelaircraft.org/files/museum/bio/Scarinzi.pdf
George
George Bain
AMA 23454
Offline Bill Adair
  • AMA 182626
« Reply #3 on: November 24, 2009, 12:21:43 AM »
Ken,
Sure brought a smile to my face, as I can still remember the first exciting flights with the Queen Bee, that I built shortly after the plans appeared in the magazine. What a blast that was!
My wife only remembers one of my control line airplanes, of the many I built over the years, and that is the little Queen Bee!  ;D
I have a like new Pee Wee set aside, just in case!
Online kenneth cook
« Reply #4 on: November 24, 2009, 03:02:27 PM »
     This past weekend, I was in North Jersey for the GSCb swap meet in which Larry attended. We did go to the field and do a little flying afterwards. I should've brought the plane as Larry was present at the field and was leaving just as I returned from lunch. It was a bit damp and chilly which was probably why more were inclined not to fly. Larry was at Brodak's this year when I approached him with the finished model. It surely did bring a smile from him. Unfortunately, I couldn't get it to run correctly. The plane then sat for a few months until I figured out a few problems with the way the engine is configured to the firewall. When you fill the plane with the tank in the upright fashion then lay the plane down the fuel runs out the bottom filler pipe. A plugged piece of extra small fuel tubing took care of this and the engine was off and running. As simple as this plane looks to make, it did have its challenges . The other problem is having large hands to get in there and adj. the needle. These little buggers can chew. Ken
