  • August 04, 2025, 03:09:59 AM
Author Topic: Guillows Profile Trainer 2  (Read 1130 times)
Offline Clay Schmidt
« on: February 17, 2010, 03:31:04 PM »
Hello Everyone,
I'm looking for plans for the Guillows Profile Trainer 2.  If anyone can tell me where I can buy a set, or if someone would be willing to copy a set, I would be willing to pay for your expense and trouble.  My brothers and I learned to fly with one of these 40 years ago and I'd like to build another.
Clay Schmidt
Clay Schmidt
Offline 11290
Re: Guillows Profile Trainer 2
« Reply #1 on: February 17, 2010, 10:01:41 PM »
FWIW:  I copied an original set a couple of years ago and had them copied 100%, it turned out that the original plans were not "full size".  I hadn't bother to check the dimensions between the plans and the actual model.  I then figured out the copy ratio and took them back to Kinko's and had them recopied to the right "full size".
I have them around here someplace.  Been cleaning the basement so I'm not sure where some stuff is hidden.  I will look in the next few days and see if I can find both the actual plans and the upscaled plans.
Evansville, IN & Orlando, FL
« Reply #2 on: February 18, 2010, 08:59:05 AM »
I'd sure like to have a copy if you run across them. I plan to re-draw the plans with CAD so  having the full size plan is not necessary.  I just need to know a true dimension such as the wing-span.
Clay
Clay Schmidt
