  • August 04, 2025, 12:54:03 AM
Author Topic: Hollow logs/Super stuntmaster  (Read 2397 times)
Offline John KruziK
« on: October 17, 2009, 02:02:16 PM »
I'm putting together a super stuntmaster. I only have the fuse. ,stab., elevator and a set of plans. My question is, plans show a cowl, problem is the back plate of a baby bee is exactly the diameter of fuse. Also have a mount for an Ame 049 that is also same size. Any ideas on how this is supposed to be accomplished.  Thanks  John
« Last Edit: February 16, 2010, 06:04:37 PM by John KruziK »
AMA 874027
Offline Robert McHam
Re: Hollow logs
« Reply #1 on: October 17, 2009, 06:35:30 PM »
That is easy to answer. Typically Scientific made the 1/8" ply front bulkhead (many of us call it the firewall) about 1/8" wider on each side, top and bottom. The cowl was usually a thin sheet of aluminum wrapped around the top and sides with the bottom open. The bottom opening is pretty much impossible to see in the artist renderings on the box or instruction sheet.
In the case of this particular model, the top of the bulkhead is even with the top of the fuselage but 1/8" wider on each side, maybe even 3/16". The bottom appears to be 1/8" to 3/16" more as well. These pictures should help.
Robert
Offline John KruziK
Re: Hollow logs
« Reply #2 on: October 17, 2009, 07:51:13 PM »
Thanks thats what I did
AMA 874027
Re: Hollow logs
« Reply #3 on: October 17, 2009, 08:06:20 PM »
So when do we get to see this plane again?
Robert
Offline John KruziK
Re: Hollow logs
« Reply #4 on: November 11, 2009, 08:04:59 PM »
Plane is finally going together. Thanks to help with plans and answers from several people. I decided to change landing gear mount. I cut a channel for each leg and a hole for top of gear into balsa. Then i inserted a piece of light ply into top of hole. Next i made cowl with plywood firewall, and epoxied it all together. This way engine doesn't hold gear in place. Thanks for all the info John
AMA 874027
Offline John KruziK
Re: Hollow logs/Super stuntmaster
« Reply #5 on: November 13, 2009, 03:58:50 PM »
Just took masking tape off.
AMA 874027
« Reply #6 on: November 13, 2009, 05:24:13 PM »
Looking good.
« Reply #7 on: November 13, 2009, 06:18:06 PM »
Well done John!
Now who would not be proud to take this to the field?
What does she weigh?
Robert
Offline Dalton Hammett
« Reply #8 on: November 14, 2009, 11:27:29 AM »
   Very neat looking little plane !!!
   Dalton H.
Dalton Hammett
Albion, Pa.
Bean Hill Flyers
AMA  29918
Offline Jim West
« Reply #9 on: February 19, 2010, 09:35:52 PM »
I love it but, it should be red and white ;D
Jim West
Engine collector
« Reply #10 on: February 20, 2010, 03:02:05 PM »
  I think you meant to say, "it should be red and white, eh?"
Offline Jim West
« Reply #11 on: February 21, 2010, 09:48:15 PM »
Oh Yeah n~
Jim West
Engine collector
« Reply #12 on: February 21, 2010, 10:30:56 PM »
Oh Yeah n~
   I've been watching a lot of curling this week - I'm picking up the vernacular, dontcha know.
