  • June 17, 2025, 11:22:36 AM
Author Topic: Rayzor combat trainer  (Read 973 times)
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« on: December 17, 2009, 10:57:22 AM »
Here's the latest iteration of my Rayzor combat trainer: 1/8" thk. sheet balsa wing for easy/speedy build, 1/8x1/2 hardwood spar for strength (and BC mount), 30" span, 142 sq. in., about 6 oz. RTF.
First pic, finished product except for top-mounted controls.
2nd pic, center section showing tapering MM hardwood.
3rd pic, 1/32" ply. fuselage top piece (extends over stab joint at rear).
4th pic, under side MM area, to be trimmed to ply. outline, 1/8" balsa filler where needed; then fuselage lower piece can be glued on, sandwiching the whole mess to make a very strong MM.
5th pic, LO guide at tip (similar piece at opp. tip without holes), tying wing pieces and spar together.
Convertible to radial mount by sawing off the front end behind engine cutout, and gluing 1/2" balsa pieces top and bottom to attach 1/8" ply. firewall to.  Pin everything with 1/8" dowels.  Pretty much indestructible.
 6th pic, I use a 3" BC with very short pushrod arm to slow the controls down
7th pic, ready for paint.
--Ray
AMA902472
Offline dankar
Re: Rayzor combat trainer
« Reply #1 on: December 17, 2009, 08:36:20 PM »
Nice looking. I built a slab combat kit is early 70's and was amazed on how well it flew. It was a kit but don't recall maker. It was stable and could cut some air.
Dan
    • Minnesotamodeler
« Reply #2 on: December 18, 2009, 02:19:16 AM »
Thanks...I've been producing variations of this design for a few years.  It flies quite well for a flat wing.
--Ray
AMA902472
