  • August 04, 2025, 03:09:17 AM
Author Topic: SABRE JET (NEW PICTURES)  (Read 1695 times)
Offline LARRY RICE
« on: August 09, 2011, 06:25:00 PM »
This is our new Sabre Jet that will be ready in a week or two.  Wing Span 18" and uses ANY .020 to .049 engine.  It is a very fast model and lots of fun.  Walt Musciano designer this one, we moved the wing up into the fuselage and added a doubler under the wing for support.  Now to paint it.
Larry
« Last Edit: August 13, 2011, 11:44:40 AM by LARRY RICE »
Offline LARRY RICE
Re: SABRE JET
« Reply #1 on: August 09, 2011, 07:00:40 PM »
This kit will replace the Dick Sarpolus F-86, Mig 15 and their double kit Mig Ally.  More kits are in the works.
Larry
Offline LARRY RICE
Re: SABRE JET
« Reply #2 on: August 10, 2011, 10:50:16 PM »
Yes, that is the one that we made.  I did not like the way the wing fitted to the bottom of the fuselage so I slotted the fuselage to slide the wing in.  I made the wing in two pieces and added a bottom piece where the two joined together.  Since most people will be using a COX engine I altered the motor mount to fit it.  I was not happy with a small rudder piece so I offset the rudder and fin.  All told I made the plane stronger and better performing.
Larry
Offline LARRY RICE
Re: SABRE JET (NEW PICTURES)
« Reply #3 on: August 13, 2011, 11:49:34 AM »
I did not do a great paint job, I know.  But I was under the gun as we have several orders for the Sabre Jet already and needed something to put on the box.  We do use customers models when they come in ... send us your photos of any Black Hawk Model.
Larry
Offline Brian Browning
Love Sabres!
« Reply #4 on: August 20, 2011, 08:33:43 AM »
But c'mon Larry.  It's a JET!  Gotta have trike gear.  Even the Germans figured that out in '43.
Keep up the good work, I've bought several of your planes from Sam's Hobbies (great folks btw, I hope and pray their health improves.)
Happily crashing,
Brian
Offline LARRY RICE
« Reply #5 on: August 20, 2011, 08:50:40 AM »
You will have to take the landing gear up with Walt Musciano, he designed this one.  I designed the ME 262 with trike gear.
Larry
