  • May 23, 2024, 10:10:08 AM
Author Topic: Cox engines  (Read 8283 times)
Cox engines
« on: December 14, 2006, 09:16:26 AM »
I want to get a Queen Bee and I have a 1/2A Snapper to build.
This probably doesn't belong here, but no one will see it in the Classifieds!!!!  **)
Anyone want to part with a running Babe Bee and a Pee Wee .020??  (I've NEVER had an .020!)  ???  ???
Cosmetics are a "non-issue".  y1
Bill <><
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Cox engines
« Reply #1 on: December 14, 2006, 03:45:50 PM »
Bill, I set up the Snapper firewall for a long-tank Cox (Black Widow, Golden Bee, etc.)--to use a Babe Bee you will have to use a 1/4" thick block under the engine, or else trim off the fuselage sides and top 1/4", or else move the firewall forward 1/4".
I was just downstairs measuring, and actually there's about 1/8" clearance behind the prop as is; so you might get by with a 1/8" spacer and a little sandpaper.
Not a major problem; just FYI.
--Ray
--Ray
AMA902472
Offline frank carlisle
Re: Cox engines
« Reply #2 on: December 14, 2006, 06:26:17 PM »
Hey Ray---we could almost call the 1/2A forum the Minnesota Modeler page!! Not too shabby.
 j1 j1 j1 **) **) y1 y1 :! :! AP^
Frank Carlisle
    • Minnesotamodeler
Re: Cox engines
« Reply #3 on: December 14, 2006, 08:01:05 PM »
Just goes to show you I'm a glutton for punishment...not many modelers specializing in the little stuff, they're smarter than that.
--Ray
--Ray
AMA902472
Re: Cox engines
« Reply #4 on: December 14, 2006, 11:22:49 PM »
--Ray
Hi Ray,
Thanks for that information!  I have a few of the big tank Cox engines, so I will go with one!  I have only flown one .049 in the past 40 years!  **)
I am REALLY looking more forward to this one each day.  ;D
Bill <><
Offline Leroy Heikes
  • ACE
Re: Cox engines
« Reply #5 on: December 15, 2006, 06:44:35 AM »
Bill;
    I'll check my stash I might have an extra 0.02. I have the one I'm going to use, but I might still have a some others in storage in a box way back under the bench. I had a coworker a few years ago give me a shoe box with several tiny engines in it. They may be 0.02 or they my even be 0.01 I will have to look.
Leroy
    • Minnesotamodeler
Re: Cox engines
« Reply #6 on: December 15, 2006, 08:34:40 AM »
Leroy,
If you do turn up a .010, I may be interested in it.  Never saw an engine that small!
--Ray
--Ray
AMA902472
Re: Cox engines
« Reply #7 on: December 15, 2006, 12:13:12 PM »
Guys,
While we're talking about needing engines....I would like to put in a request for a TeeDee .049------I have a Pinto kit here I'd like to put one in.
Frank Carlisle
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #8 on: December 16, 2006, 10:06:53 AM »
Hey Frank the Pinto brings back alot of memories. I learned the whole pattern on a Pinto. It was also the first plane I built from plans. Wow it was also the only plane that flew right off the board, I still have the TD I used in it. And the tail I have a picture but it's in very bad shape.
I built it in 1976.
You don't stop flying cause your get OLD
You get OLD cause you stopped flying
St Peter MN
Present Master of the Figure 9
Re: Cox engines
« Reply #9 on: December 16, 2006, 02:59:24 PM »
You're right about the picture being raatty Mike, but the plane looks great. Now if I can just get my hands on a good TEE DEE................................... <=
Frank Carlisle
Offline Bill Gruby
Re: Cox engines
« Reply #10 on: December 16, 2006, 03:05:07 PM »
If you haven't seen this yet, you 1/2A enthusiasts are gonna love this.
Link         http://www.mh-aerotools.de
On English side click on Model Aero-----Scroll index to Cox Engines and have fun, you might want to bookmark this one.
Bill Gruby     AP^
Bill Gruby
AMA 94433
MECA 5393-10
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #11 on: December 16, 2006, 03:10:34 PM »
I've got 3 plans and a RSM kit of it. I was going to use a norvel in my next one. I have 4 norvels. They all seem to run great. As good or better than the TD.
St Peter MN
Re: Cox engines
« Reply #12 on: December 16, 2006, 03:31:32 PM »
Thanks for the very interesting link you left us Bill. It's great to find this stuff.
Mike are you going to use the Norvel .049 or the .061?
Frank Carlisle
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #13 on: December 16, 2006, 03:50:59 PM »
I don't know. An interesting story though my son designed and built a P38 profile for 1/2 A's like Dick Sarpolis. He grab 2  novel motors to put on it. It flew great and sounded neat. It wasn't till it crashed did we know it had one .049 and one .061. couldn't tell the difference.
St Peter MN
Re: Cox engines
« Reply #14 on: December 16, 2006, 11:02:41 PM »
heh heh heh.................. HB~>
Frank Carlisle
  • ACE
Re: Cox engines
« Reply #15 on: December 17, 2006, 08:43:35 AM »
Frank;
    You are in luck! I have a TD 0.049 you could have it is gummed up, and doesn't have the prop screw. I'll let you have it if you want. I had it in a RC plane back in 88-89, and it was at the bottom of an old box.
Bill,
    I have a spare 0.020, but two of the mounting lugs are broken, the needle valve is bent and no glow plug. I'll also let you have that one if you want.
    I was unable to find the little 0.010 yet.
Leroy
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #16 on: December 17, 2006, 09:55:10 AM »
Hey Frank I've got a bunch of 5-40 allen bolts for the cox prop bolts let me know if you need some or one.
St Peter MN
    • Minnesotamodeler
Re: Cox engines
« Reply #17 on: December 17, 2006, 04:02:02 PM »
Sounds like you're in business for your Pinto, Frank.
Pics, you know...
--Ray
--Ray
AMA902472
Re: Cox engines
« Reply #18 on: December 17, 2006, 05:36:32 PM »
Leroy -- Mike here is my address........If you guys haven't got a copy of my Bi-Slob video '06.......please let me send you each  copy to show my gratitude.
Frank Carlisle
5930 Hereford
Detroit, Mich. 48224
« Last Edit: December 18, 2006, 06:20:23 AM by frank carlisle »
Frank Carlisle
  • ACE
Re: Cox engines
« Reply #19 on: December 18, 2006, 09:01:37 AM »
Frank;
    I'll get that engine in the mail this week. Is that a new Bi-Slob video? If it is I'll take a copy. I have the first Bi-Slob video you did.
Leroy
Re: Cox engines
« Reply #20 on: December 18, 2006, 10:40:15 AM »
Leroy----I'm planning on putting together Bi-Slob 2 during the Christmas break. I'll send you the first copy. I should probably utograph it for you so tht it will be worth more when I am rich and famous.
Frank Carlisle
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #21 on: December 18, 2006, 06:37:00 PM »
I've got the address on the envelop and am digging out the bolts you my have to cut them shorter for your needs. I got them long way back when that way they would work with any spinner.
Bi-Slob video that'll just make me want to build one. Then I'll become addicted %^ %^
St Peter MN
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #22 on: December 18, 2006, 06:59:12 PM »
Their in the mail j1 :##
St Peter MN
    • Minnesotamodeler
Re: Cox engines
« Reply #23 on: December 18, 2006, 11:58:34 PM »
[ I should probably utograph it for you so tht it will be worth more when I am rich and famous.
I don't know if we can wait that long.
--Ray
--Ray
AMA902472
  • ACE
Re: Cox engines
« Reply #24 on: December 19, 2006, 05:08:17 AM »
Frank;
    You are allready famous, or at least your a legend here on the west side of the state.  **) **) **) **)
    The rich thing you'll just have to work on that.  j1 j1 j1 j1
Leroy
PS I have those engines boxed up, but forgot to put them in the car last night. HB~>
Re: Cox engines
« Reply #25 on: December 20, 2006, 08:33:02 AM »
OK, guys, now that y'all have had your "Mutual Admiration Society Meeting" ( **) ),
DOES ANYONE HAVE A SPARE BABE BEE .049 (short tank)??
That was the original intent of the post.  y1 ;D ;D
Thanks!
Bill <><
    • Minnesotamodeler
Re: Cox engines
« Reply #26 on: December 20, 2006, 09:00:49 AM »
Hey Bill,
I have a short tank for a Babe Bee, just no engine...it will fit, of course, on any of the reed-valve .049s, including those cheap "sure-start"s.  You could build your own Babe Bee!
If you could use it, let me know.  Free for nothin', it's just gathering dust here and I'll never use it.
--Ray
--Ray
AMA902472
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #27 on: December 20, 2006, 03:36:12 PM »
I've got an extra one too j1 %^
St Peter MN
  • ACE
Re: Cox engines
« Reply #28 on: December 22, 2006, 10:49:35 AM »
Bill;
    I sent the engine to you. I was able to get it in the mail Wed.
Frank;
    I have that little TD in the mail to you also. The Needle valve is taped to the inside of the box.
Leroy
Re: Cox engines
« Reply #29 on: December 22, 2006, 12:24:13 PM »
Bill;
Frank;
Leroy
Thanks, Leroy!
Bill <><
Alan Hahn
Re: Cox engines
« Reply #30 on: December 22, 2006, 05:40:01 PM »
One comment about not being able to tell the 061 Norvel from the 049. I have flown both, and a good 061 can turn a black 5x4 Tornado Magnum >22Krpm, but the 049 needs the 5x3 to get that fast. Could be your son (luckily) had the 061 on the inboard wing.
Re: Cox engines
« Reply #31 on: December 24, 2006, 12:19:56 AM »
Bill;
Frank;
Leroy
Hi Leroy,
Got the little bugger today!  Just in time for Christmas.  ;D
Thanks, and Merry Christmas!
Bill <><
Re: Cox engines
« Reply #32 on: December 24, 2006, 12:21:14 AM »
Hey Bill,
--Ray
Hi Ray,
That would be great!  I have a couple of good crankcases (complete) that I can use it on.
Bill <><
    • Minnesotamodeler
Re: Cox engines
« Reply #33 on: December 24, 2006, 01:05:02 AM »
Hi Bill,
On its way (well, will be Tuesday).
--Ray
--Ray
AMA902472
Offline Clancy Arnold
Re: Cox engines
« Reply #34 on: December 24, 2006, 08:13:26 AM »
Mile
Part of the reason your son could run mixed sized engines on his P-38 is the design "Kelly" Johnson came up with in the first place.
Two tests of his design:  Lackheed test pilot Tony LeVier once took a P-38 off on one engine by taxing in ever greater circles until he had rudder control to hold it straight.  The second test was at the 1983 FAI Scale team trials when I lost the left engine on the 5th lap but was able to complete the 10 laps to qualify the flight.
 Clancy
Clancy Arnold
U/Tronics Control
Offline Mike Spiess
  • bikemike
  • AMA #4060
Re: Cox engines
« Reply #35 on: December 24, 2006, 08:37:41 AM »
Hey Clancy
The plane would fly really well on one motor inboard or out board. I'm planning on building another this winter just for fun.
St Peter MN
Re: Cox engines
« Reply #36 on: December 24, 2006, 05:16:03 PM »
Got the TeeDee yesterday Leroy.....Thanks man. I'll clean it up aand put it to good use.
I also got the prop screw from you Mike so I'm allset. Feels great thanks guys.
Frank Carlisle
Re: Cox engines
« Reply #37 on: December 24, 2006, 07:41:32 PM »
My P-38 was in Model Aviation, March 1986 and is available as Plans # 505.  It is bigger that what we talk about here, 2 each ST 35's, 65 inch wing span and 12 lbs.
Clancy
« Last Edit: December 28, 2006, 07:40:16 AM by Clancy Arnold »
Clancy Arnold
U/Tronics Control
Offline Robert McHam
Re: Cox engines
« Reply #38 on: January 06, 2007, 07:00:30 PM »
frank carlisle said:
"I have a Pinto kit here I'd like to put one in."
I loved my Pinto years ago. ai bought the plans from Flying Models soon as I could scrape uip the money ans built my first and only model of it.
Thing is, I had no idea it wae available inh kit form till recently. Was it kitted by someone else before RSM? If so by who and when? I scratched mine. Would have been nice to have had a kit.
Robert
Offline Joey Mathison 9806
Re: Cox engines
« Reply #39 on: January 07, 2007, 04:51:50 PM »
some 1./2 motors
200 mph man ama#9806 joey mathison
    • Minnesotamodeler
Re: Cox engines
« Reply #40 on: January 07, 2007, 09:41:16 PM »
I don't see an .010 in the bunch.
--Ray
--Ray
AMA902472
Offline George
  • Love people, Use things.
Re: Cox engines
« Reply #41 on: January 09, 2007, 08:27:40 AM »
--Ray
No, but I think there are a couple of K&B Infant .020's and a K&B .035 over toward the left.
George
George Bain
AMA 23454
Re: Cox engines
« Reply #42 on: January 10, 2007, 06:37:05 PM »
good eyes there george ::)
