  • July 31, 2025, 08:07:10 AM
Author Topic: Cox 09 Medallion  (Read 1846 times)
Offline Bootlegger
Cox 09 Medallion
« on: September 01, 2021, 07:29:59 AM »
  Guy's who can tell me he venturi size of the Cox medallion size as the one I have has a spray bar thru it..  Much obliged.      H^^ y1 #^
8th Air Force Veteran
Gil Causey
AMA# 6964
Re: Cox 09 Medallion
« Reply #1 on: September 01, 2021, 10:25:04 AM »
  Take the spray bar out and measure it with your dial calipers. You may be able to sneak the points of the caliper jaws in and around the spray bar as it is. You can also insert the shank of a number, letter or fractional drill into the throat and then measure that with a micrometer.
Offline Bootlegger
« Reply #2 on: September 01, 2021, 12:10:46 PM »
  Thanks Dan, That makes me obliged to you, again thanks..
Gil Causey
AMA# 6964
