  • August 01, 2025, 05:03:59 AM
Author Topic: Still on Medallion engines  (Read 2047 times)
Offline Bootlegger
« on: September 02, 2021, 03:23:07 PM »
  Guy's I have two medallion 09 engines that I can not get apart using the proper wrench, I can't get the front end to come lose to remove the shaft and other front end parts, it seems that both
 of them are bound and will not unscrew I sure don't want to "bugger up" the case or shaft to open them up.  I have done several medallion and T  D engines the same way with no problem.  I have mounted the block in a small vice but still can't front end to unscrew..   Any help/suggestions sure will be appreciated..   Much obliged... H^^   D>K   Hope that I made myself clear... HB~> HB~> HB~>
8th Air Force Veteran
Gil Causey
AMA# 6964
Offline kenneth cook
Re: Still on Medallion engines
« Reply #1 on: September 02, 2021, 04:37:22 PM »
              Pour some lightweight oil around the lock collet and heat, heat , heat. Don't use a torch, use a heat gun. Use the smoking oil as a gauge as too how hot your getting it otherwise you will melt the carb body.
Offline Bootlegger
« Reply #2 on: September 02, 2021, 07:50:24 PM »
Thanks a lot, will try that tomorrow.. H^^
Gil Causey
AMA# 6964
Offline Bootlegger
« Reply #3 on: September 03, 2021, 04:44:17 PM »
   Ken, I got to try your "trick' w/heat, and it worked like a champ, wanted to let you know, and say "much obliged"  thanks again... H^^ :!
Gil Causey
AMA# 6964
