  • June 18, 2025, 06:11:20 AM
Author Topic: Tech Terror - Zombie version!  (Read 1604 times)
Offline Larry Renger
« on: March 11, 2011, 11:08:22 PM »
 Well, having spattered my "nice" Tech Terror just a week before needing it to fly at VSC, I have spent an amazing amount of time replacing the center section of the wing and the rest of the model.
The fuselage, at best, should be named Igor.  I vote this the Zombie Tech Terror!  Photos attached.
Re: Tech Terror - Zombie version!
« Reply #1 on: March 12, 2011, 05:41:05 AM »
Nice SAVE.  Love that classic-legal prop to!
« Reply #2 on: March 14, 2011, 08:13:50 PM »
I am here in Tucson, and put in the first 3 flights on the ZTT.  Balance seems good. The tip weight may be a bit much, but I'll work on that later.  I am tuning the pushrod length and handle settings.  It should be close to trim tomorrow.  Unfortunately, this evening, something slid in the car and cracked the vertical tail. This is one hard-luck plane, it seems! Easily fixed as soon as I get some CA (available at the field, fortunately).
Wish me (better) luck!   :P
Offline John Rist
« Reply #3 on: March 15, 2011, 02:23:11 AM »
I am wishing you, not just better luck, but really good luck.  May your lines stay tight, you flight be true and according to plan, and above all avoid the dreaded figure "9" !!!!
 #^   #^    #^    #^   #^    #^    #^    #^    #^    #^    #^    LL~
« Reply #4 on: March 15, 2011, 09:00:55 PM »
Tried one with this plane, and didn't like it!   :X :X :X
Oddly, the engine wouldn't run well with the wood tornado prop, but likes a nylon one.  Go figure!  HB~>  I am running 15% nitro, a Merlin glowbutton and 4 washers.  Excellent power despite the altitude and temperature.
« Reply #5 on: March 16, 2011, 09:36:37 PM »
This plane specializes in involuntary figure 9s!  This time the clips at the handle hung up!  HB~>
Fortunately I have a backup model to fly tomorrow, but still.... HB~> HB~> HB~>
« Reply #6 on: March 18, 2011, 05:29:58 PM »
Sheesz that bird got bad karma!  Cannot believe the run of bad luck you've had with it.   HB~>  :'(
Maybe you should rename this one DESIGNMAN's Terror!
« Reply #7 on: March 22, 2011, 12:57:05 PM »
Yup, 5 crashes, all due to equipment failures of some sort or other!   ~^  :X  HB~>
The wing is repaired, and now I need to fix the fuselage.  Should be ready to go by the weekend.
« Reply #8 on: March 23, 2011, 01:42:55 PM »
"Zombie Tech Terror"
I suppose you have to put a round in the cylinder head in order to stop it! :o
