  • June 15, 2025, 09:25:59 PM
Author Topic: SIG KRICKET  (Read 1181 times)
Offline Bob Lafayette
  • AMA L265754
SIG KRICKET
« on: January 24, 2020, 03:30:18 PM »
Anyone build one from kit or have plans?
Offline afml
Re: SIG KRICKET
« Reply #1 on: January 24, 2020, 05:31:06 PM »
I built one in the 1969 NATS hangar at Willow Grove, between the days I flew.
In fact, I bought it at the  NATS NAVY Hobby Shop there in the hangar.
Mine was powered by a Cox Golden Bee.
A Black Widow would yield a more appealing performance.
The foam wing was a bit heavy and later....Brittle.
The wing tips were heavy plastic.
Plans were assembly type like the Sterling Ringmaster.
Much later, a neighbor was very interested in the little plane.
So we drew up ribs that matched the airfoil of the foam wing.
Flew GREAT!
If I find any remains or assembly plans, I'll post them here.
Good luck & "Tight Lines!" H^^
Wes
Wes Eakin
Offline kenneth cook
Re: SIG KRICKET
« Reply #2 on: January 25, 2020, 05:51:01 AM »
              I built one a few years ago. I thought it flew terrible. The wing is not symmetrical which I feel was the most of the problem. The solid foam wing is quite heavy .  In addition, the wingspan in my opinion wasn't quite enough for the plane. Mine was powered with a Black Widow and while it would go fairly fast in level flight, it floundered about when you maneuvered.
