  • July 02, 2025, 11:04:47 PM
Author Topic: AVENGER IN THE WORK SHOP (NEW PICS)  (Read 1586 times)
Offline LARRY RICE
« on: June 20, 2010, 04:15:57 PM »
     We are finishing up a new Avenger kit, it is drying now and will be finished next week.  I expect to have it available before the 4Th of July.  Designed by Paul E. Del Gatto for Scientific models in the late 50's.  Hollow log, 18" span with vac. canopy, guns and antenna optional.  This one has a flat wing but the ones in the kits will have an airfoiled wing.  The model builds easy but the designing to be able to kit it was time consuming.
    Just thought I would show you what we are working on. I will update when it is finished.
Larry
« Last Edit: June 24, 2010, 06:21:32 PM by LARRY RICE »
Re: AVENGER IN THE WORK SHOP
« Reply #1 on: June 21, 2010, 08:03:38 AM »
Looks great.  Too bad it is not 36 inch wing for my McCoy 60 Redhead with Bill Johnson throttle.   H^^
Offline LARRY RICE
« Reply #2 on: June 21, 2010, 08:40:58 AM »
Are you saying a twin Avenger (F-82 style) with a .60 on it ... Hummm sounds interesting.  LL~
   Doc, I have been looking at all of the pictures from Brodak's and I was wondering why so many people were building their models up side down ... with the canopy on the bottom and the wheels up in the air?  LL~
Larry
Offline Bill Heher
  • Fix-it
« Reply #3 on: June 21, 2010, 04:58:12 PM »
Larry- that is a great looking model!  I will be getting one- even though I have plenty of other projects. I have a nice rebuilt Babe Bee that will look great in that cowl!
Bill Heher
If it's broke Fix-it
« Reply #4 on: June 23, 2010, 08:00:57 AM »
Larry
No Larry, thinking of a Class II or I carrier kit.  As far as all the planes built inverted, that is one of the things that Elwyn does best.  He sent me a pic of my Staggering and with the clear sky I had it hung upside down for a long time until someone pointed out the little cloud under the landing gear. H^^
Offline LARRY RICE
« Reply #5 on: June 23, 2010, 08:36:53 AM »
Just jerking your chain, Doc.
     I have this great looking plan for a Dauntless for carrier but it requires planking.  I know that planking is easy to do but the general public goes screaming out of the room at the thought of it.  So I guess that will not work out.
Larry
« Reply #6 on: June 23, 2010, 09:00:37 AM »
Could do it like the Berkeley Gaurdian.  The formers were six sided with planks glued on.  Then it was sand and carve to get the shape.   H^^
Offline LARRY RICE
Re: AVENGER IN THE WORK SHOP (NEW PICS)
« Reply #7 on: June 24, 2010, 06:23:32 PM »
Finished:
« Reply #8 on: June 25, 2010, 08:41:56 AM »
That looks nice.   H^^
Offline LARRY RICE
« Reply #9 on: June 25, 2010, 08:59:21 AM »
Thanks, Doc.
     Here is how to do 1/2A carrier.  Install an arresting hook in the down position with enough flex to allow the tail to sit down for takeoff.  Attach a string to the tail, so that it can be pulled by the pilot.  Take off, fly fast for time then pull the tail inward while lifting the nose of the plane, this will slow the model. Finish the slow timing and go for an arrested landing.  With practice it is easy.
Larry
« Reply #10 on: June 27, 2010, 01:17:37 PM »
Sound like how the WAM group used to do it according to what I read way back then.  Won't let us use it in AMA compitition. H^^
