  • August 04, 2025, 02:17:35 AM
Author Topic: cox parts  (Read 1685 times)
Offline bob werle
cox parts
« on: July 16, 2010, 12:43:02 PM »
does anyone know the size of the venturi o-ring on the Golden Bee and other reedies?
ama 5871
Re: cox parts
« Reply #1 on: July 16, 2010, 02:29:16 PM »
Little.
I think it's 1/8" ID and 1/32" diameter ring.  I also think it's hard to find -- I can never seem to find it looking in McMaster-Carr.
If you have a steady hand you can cut a chunk of small silicone fuel tubing about 1/32" long and make it work.  The silicone will be squishy enough to absorb some irregularity in the cut, but not a whole lot -- which is why you need the steady hand.
Dwayne
Re: cox parts
« Reply #2 on: July 16, 2010, 03:29:21 PM »
Found this, it's called Baby Bee tune up kit but has what you are looking for, besides you can always use an extra reed and case gasket anyway.. ;D
http://coxengines.ca/product.php?productid=129&cat=25&page=1
Offline Bill Barber
Re: cox parts
« Reply #3 on: July 16, 2010, 08:06:58 PM »
   Or you can just buy a set of 3 o-rings  listed below .
              http://coxengines.ca/home.php?cat=25&sort=orderby&sort_direction=0&page=4
   Cheers , Bill barber
AMA 325076
Dwayne
Re: cox parts
« Reply #4 on: July 17, 2010, 07:49:04 AM »
Perfect  y1
Offline William Lee
Re: cox parts
« Reply #5 on: August 30, 2010, 11:21:53 PM »
Bernie has bulk O rings as well.  I ordered 10 at a time.  Look for the BULK items listed on his site. Cox International.
Bill Lee (the other one) AMA NCC1701
 Remember when flying inverted; down is up, and up is expensive.
