  • August 04, 2025, 04:47:29 AM
Author Topic: Sky Sport upgraded  (Read 1085 times)
Offline Larry Renger
Sky Sport upgraded
« on: August 30, 2010, 09:00:20 AM »
I just sent Eric Rule the drawings for the Mk 3 version of the Sky Sport.  The fuel tank volume is expanded, the landing gear position improved, the wing and thrustline have been moved closer together and a few minor corrections made to the plans.
Sadly, my Mk 2 bit the asphalt on Saturday.  Ran out of fuel on entry to the overheads.  Its hard to run straight down to maintain line tension.  The Mk 1 is still alive and well, hanging in my garage ready to fly.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
Re: Sky Sport upgraded
« Reply #1 on: August 30, 2010, 01:47:38 PM »
That is unfortunate...1/2As generally don't have enough mass for inertia to carry them over the top; mine, anyhow, tend to just fall down on my head in such a case!
I smooshed up one of my Minnie Deltas last time out, wind extremely variable, it "varied" 180d. while I was coming back up from an outside loop. I no longer even try to outrun slack lines--managed to back up a few feet before it impacted, tore the motor mounts out (beam mounts).  It's been patched up a few times before, getting kinda heavy, so I'm thinking it's trash.
--Ray
AMA902472
Offline George
  • Love people, Use things.
« Reply #2 on: August 31, 2010, 08:26:43 AM »
...Its hard to run straight down to maintain line tension...
Agreed! I think most of us just run...preferably with our arms above our head!  8)  ::)  ;D
George
George Bain
AMA 23454
