  • July 16, 2025, 08:25:20 PM
Author Topic: 1/2a Line Lenght (061)  (Read 399 times)
« on: June 21, 2025, 03:21:46 PM »
Is anyone flying Norvell .061 stunt ship on 52 ft lines?
I've got a Pathfinder that flies good on 42' but the engine is running in a flat 4 stroke to keep the lap times reasonable. I want to lean it out for more power with a bigger prop and longer lines to see it's potential.
MM :)
Offline Larry Renger
Re: 1/2a Line Lenght (061)
« Reply #1 on: June 21, 2025, 04:35:57 PM »
Antone Kephart flew a Baby Magician on 52’ .008 lines. Power was a Tee Dee 049 running high nitro and bladder pressure. I suspect you could get that performance with the .061.
My experience with the .061s is a 5.5x2.5 prop works best. The engines like to rev, not lug big props. Overheating is the issue.
« Reply #2 on: June 25, 2025, 02:05:29 PM »
Have you tried the apc 6-2 tooth pic? Works good on my Pathfinder with 20% nitro.
I copied a Rev Up 6-3 wood in CF and depitched the tips to 1.75. Haven't had a chance to try it but it has a more stunt like blade area so we'll see.
MM :)
« Reply #3 on: June 26, 2025, 02:33:48 PM »
  I check the lines I have been flying the Doodlebug Brothers .061  with a Norvel .061 and I'm at .45 feet eye to eye, and still fast, so might make a jump to 48 ft and see what happens. Benn using 20 lb Spectra but might drop down a bit if I go longer Weather has not been friendly this year. It's either been rainy wet and windy, or blistering hot now and windy!! Not optimum 1/2A weather!!
« Reply #4 on: June 26, 2025, 04:54:43 PM »
Here in Dallas there are two 1/2A times a day.  First light to 1hour past sun up and hour surrounding sun down.  The rest is for the big stuff.  Pitty, no one flies 1/2a around here anymore.  If we did we would be blind from the sun and the birds would have eaten our planes.  :-X
