  • July 08, 2025, 03:07:35 AM
Author Topic: 1/2 launcher for grass  (Read 9770 times)
« on: April 27, 2014, 10:33:44 AM »
Guys,
Our group is having some fun with 1/2 A's but due to the field being grass have had to hand launch all the ships. This has proved to be adventurist. Sometime smooth, sometime OMG, sometime DUCK!!!!
I was wondering it anyone has designed a simple launcher that would allow reliable launches? I was thinking of something out of PVC tubing that would allow two rails and a pin slider that drop after it leaves the end of the rails. I also thought about something like the old pin dollies we used for speed ships but the rail launcher seems simpler to build. Any ideas?
Best,        DennisT
  • Gravitywell
Re: 1/2 launcher for grass
« Reply #1 on: April 27, 2014, 11:21:12 AM »
Just get an old cardboard box and make yourself a small airfield in the grass.  Doesn't take much, its what we used to do all the time. H^^
Glenn Reach
Westlock, Alberta
gravitywell2011 @ gmail . com
Offline John Rist
« Reply #2 on: April 27, 2014, 01:30:49 PM »
In the past I have used a card table.  Remember to step back after launch.  Works best if 1/2 A being launched has a little zip.  It works because you have a 2' + drop off of the edge of the table to get going.  In most cases the airplane is flying time it clears the table.
Offline Bill Adair
  • AMA 182626
« Reply #3 on: April 27, 2014, 03:44:03 PM »
John is correct, but if you are slightly underpowered or a bit overweight - there are plenty of double width folding tables available. Alternately, clamp a piece of plywood to the table top with c-clamps to add runway length.
A friend built a beautiful runway, complete with mini control tower, runway lights, windsock, glow driver hook up, and fueling facilities! Looks and works great!
Offline david beazley
« Reply #4 on: April 27, 2014, 04:24:06 PM »
We just added a couple 4X6' rubber stall mats from Tractor Supply to our circle.  They are 3/4" thick and heavy so they wont blow away but still can be dragged around for wind changes.
AMA # 2817
« Reply #5 on: April 27, 2014, 05:36:44 PM »
If the plane has enough zip then do a sleeve launch.  Google it, or search on YouTube for a video.
Offline Larry Renger
« Reply #6 on: April 28, 2014, 08:22:35 AM »
I use a strip made from scrap signs. The first one was old political signs salvaged after an election, the one in the photos is made from a batch of mis-printed signs donated by a printshop. They were happy to get rid of them without having to have them hauled away. I use duct tape for hinges, alternating so the panels fan-fold neatly when not in use.
« Reply #7 on: May 03, 2014, 06:10:35 AM »
I use a Harbor Freight knock-off of the Black & Decker Workmate as the stand.
On top of that goes a clamp-on plywood deck with a standard pull-cord release.  There is some old carper stapled on to give traction and keep the model pointed forward.  It works OK for testing hollow logs.
« Reply #8 on: May 20, 2014, 12:15:27 AM »
A PVC lawn table, a stiff folded bath mat with the rubber on the inside(best when it gets oily), a bungee cord to follow the TE of any plane to keep it from twisting, a brick to re-enforce that, and a guy line staked into the ground to keep it from being pulled over. For underpowered planes I strap it atop a bar stool. Set up properly, It's safe and secure and only takes a gentle pull to free the plane.
Jim Roselle
« Reply #9 on: May 20, 2014, 06:34:12 AM »
I copied Rustys' setup and it works great. I use  two milk crates stacked and secured to each other with zip ties, an old t- shirt stands in for the bath mat. I secure it to the ground with tent stakes.
Jim
« Last Edit: August 22, 2014, 09:59:10 AM by Jim Roselle »
« Reply #10 on: May 24, 2014, 06:48:49 AM »
I looked it up and found this......
pretty great idea.
« Last Edit: May 24, 2014, 07:13:43 AM by Shug Emery »
« Reply #11 on: May 24, 2014, 07:31:48 AM »
Reminds me of this funny one. If you haven't read it, check out reply # 2 in this thread:
http://stunthanger.com/smf/index.php?topic=4712.0
Rusty
« Reply #12 on: May 24, 2014, 07:33:12 AM »
Oops, malfunction. Double post.
Offline Phil Krankowski
« Reply #13 on: May 24, 2014, 08:21:53 AM »
I copied Rustys' setup and it works great. I use  two milk rates stacked and secured to each other with zip ties, an old t- shirt stands in for the bath mat. I secure it to the ground with tent stakes.
Jim
I did similar, and probably stole it from the same source!  I use the frame of an old trash compactor as a table, very stable, and very heavy, but not so portable (I fly in my side yard so no problem).  I use an old bath towel clamped to a board as the wing wrap.  I plan to switch the clamps to wood screws at some point, but I haven't needed all my clamps recently.  I use my battery tray (3 D cells) as the weight on the wing to adjust tension.  For slab wings I use some foam insulation board that I have on a tether so the wing can slide out easily.
Phil
Offline Carl Cisneros
« Reply #14 on: June 09, 2014, 01:10:01 PM »
Frank Hunt and a couple of us jet speed fliers up in the Merced CA area used to do pretty much the same thing back in the 70's
for launching our CL jet speed planes when no one else was around to help out.
(refering to the 1st video above.)
BUT, we used a spare car tire assembly instead of the tent peg and tube.  LOL
talk about living danerously!!!!!!!!!!!!!!!!
Heck, we didn't even think about safety back then.
We just wanted to fly.
Carl R Cisneros, Dist IV
Control Line RB
Offline YakNine
« Reply #15 on: August 22, 2014, 09:02:30 AM »
Just make sure you have a post to put the handle on in case of a premature release, I use an old railroad spike. Its amazing how far a Sterling beginners Cherokee can travel at 45° by it self before it runs out of fuel on a golden bee tank, I would say it was at least 600 feet !  n~
AMA 85135        GSCB
« Reply #16 on: August 22, 2014, 09:14:40 AM »
Anchor the safety thong instead of the handle.  Will automatically get full down on accidental release.
