  • August 02, 2025, 03:32:46 AM
Author Topic: Adapt a medallion NVA to an AP Wasp?  (Read 3381 times)
Offline Target
  • C/L Addict
« on: January 31, 2019, 09:46:05 PM »
Has anyone checked to see if a Medallion NVA would work in the bolt hole (drilled out) of the AP wasp for conversion to C/L?
Thanks in advance. Not near my engines for a while.
R,
Target
Chris
AMA 5956
Offline 944_Jim
Re: Adapt a medallion NVA to an AP Wasp?
« Reply #1 on: February 01, 2019, 05:15:23 AM »
T,
Are you thinking of running the case open with the NVA and bladder? Or are you going to make some venturies?
I have spare NVAs and an AP, so I'll try to check your "test" this weekend. Hit me up if I forget.
« Last Edit: February 01, 2019, 08:25:22 AM by 944_Jim »
Offline Target
  • C/L Addict
« Reply #2 on: February 01, 2019, 03:13:56 PM »
I was thinking with a venturi Jim. For uniflow and for flying stunt.
Chris
AMA 5956
« Reply #3 on: February 01, 2019, 04:30:54 PM »
You can always make the venturi a bit long and put the needle valve in the venturi, then mount the venturi the way the original carb did.
« Reply #4 on: February 01, 2019, 04:48:39 PM »
   There was a thread on the 1/2A section here not long ago about modifying a TD venturi and mounting it to the Wasp .061, so you might want to search the forum here. I did one just to try it and it worked out OK. i bought all the stuff from the typical Cox vendors on eBay and followed some one's detailed instructions from the thread. I haven't run it yet but have no reason to think it won't work.
Offline 944_Jim
« Reply #5 on: February 01, 2019, 05:43:57 PM »
Target,
PM your email address. I have a few pix for you. They are too big to post here.
Offline Target
  • C/L Addict
« Reply #6 on: February 01, 2019, 06:31:09 PM »
Will do.
Chris
AMA 5956
Offline Larry Renger
« Reply #7 on: February 08, 2019, 04:50:33 PM »
The Tee Dee venturi works great in the AP Wasp. If I didn't have the Holuscko venturis, that is what would be my choice.
Easy peasy adapter! Chuck a piece of Nylon or Delrin rod into your drill press and run a file over it until it is the right OD. Sloppy is no problem. Then drill it slightly undersized for the thread OD and you can just force the venturi to thread into it. No lathe or taps required, though they would do a better job. Jb weld the unit into the intake (sparing on the epoxy, you do want the crankshaft to continue to rotate! LL~)
Or buy a Norvel Big Mig and be happy.
