  • August 02, 2025, 05:23:44 AM
Author Topic: Norvel  (Read 2087 times)
Norvel
« on: February 02, 2019, 01:53:32 PM »
Picked up a spinner for the TeeDee/Medallions today at the swap meet.   The gentleman throwed in the matching spinner for the Norvel.   Does it have the same threads as the Cox engines?    Guess I could go to the shop and try them,  but I'm lazy today as I got up too early. D>K
Offline kenneth cook
Re: Norvel
« Reply #1 on: February 02, 2019, 03:38:56 PM »
              No,  the Norvel is metric.
Re: Norvel
« Reply #2 on: February 02, 2019, 03:40:13 PM »
The Norvel .049/.061 engines use a 3 mm bolt to hold the propeller.
Re: Norvel
« Reply #3 on: February 03, 2019, 03:18:25 PM »
Thanks gentlemen. H^^
Offline Skip Chernoff
Re: Norvel
« Reply #4 on: February 04, 2019, 08:35:33 PM »
I had my Big Mig 061 powered Pinto out yesterday. The engine ran well,and I have to get some longer lines!!!!
Offline 944_Jim
Re: Norvel
« Reply #5 on: February 04, 2019, 09:11:20 PM »
Slightly off topic, just in case you run out of Norvels...the AP uses a 4mm stud, just like the Norvel .074.
I installed a Cox 3-blade prop AND spinner by drilling out the Cox spinner nut and tapping it for the slightly larger 4mm shaft. So far, so good!
