  • August 01, 2025, 08:13:11 PM
Author Topic: 1/2 A Pathfinder  (Read 2517 times)
Offline Vincent Corwell
1/2 A Pathfinder
« on: May 28, 2007, 06:42:13 AM »
Finished the 1/2A Pathfinder kit
AP 061 motor, not yet flown, needed 1 ounce of lead in nose to balance
now weighs 15 1/2 ounces.
Regards to all
Vincent
Offline Larry Renger
Re: 1/2 A Pathfinder
« Reply #1 on: May 28, 2007, 08:16:26 AM »
Very pretty!  What is the finish?  What lines and prop do you intend to use?
I have now run 3 AP Wasps, and find that to extract power, you need to let them rev - at least 19K on the ground.  The APS 6x2 and 5.7x3 seem to be the best available props.  If you need still more speed, a Master Airscrew 5.5x4 cut to 5" should work.  A C*x 6x3 proved too much load for mine, dragging the r's down to 14,9K, a number worse than I would expect from a Black Widow.  With a Tornado 5x3, the r's went over 23K, and the air blast was stirring up grass 30 ft away.  Big difference.
Offline minnesotamodeler
  • Me and my Chief Engineer
    • Minnesotamodeler
« Reply #2 on: May 28, 2007, 01:34:32 PM »
Now that's just a pretty plane, no matter how you look at it.  Let us know how it flies.
--Ray
--Ray
AMA902472
« Reply #3 on: May 29, 2007, 01:28:43 AM »
Thanks for the compliments friends,
I have APC 5.7 x 3 and 6 x 3 and Master 6 x 3
Starting with 38' lines
The finish is mostly Solarfilm with small amount of paint
around the engine & tank area
will post  more next month , when flown , hopefully still
in one piece!!
Vincent
Offline Roger Vizioli
  • CLiner
« Reply #4 on: May 29, 2007, 09:09:23 AM »
Vince,
Sent you an e-mail.
Roger
Roger Vizioli
AMA L-2408
Florida/Space Coast
« Reply #5 on: May 30, 2007, 01:05:53 AM »
Many thanks Roger
unfortunately I wont get to read that until
Friday night, different puters, office n home
then Saturday morn 04:30 away on holiday
for 8 days
appreciate your attention
will reply direct when I get to it
Vincent
