Building Tips and technical articles. => 1/2 A building. => Topic started by: Vincent Corwell on May 28, 2007, 06:42:13 AM
Finished the 1/2A Pathfinder kit
AP 061 motor, not yet flown, needed 1 ounce of lead in nose to balance
now weighs 15 1/2 ounces.
Regards to all
Vincent
Very pretty! What is the finish? What lines and prop do you intend to use?
I have now run 3 AP Wasps, and find that to extract power, you need to let them rev - at least 19K on the ground. The APS 6x2 and 5.7x3 seem to be the best available props. If you need still more speed, a Master Airscrew 5.5x4 cut to 5" should work. A C*x 6x3 proved too much load for mine, dragging the r's down to 14,9K, a number worse than I would expect from a Black Widow. With a Tornado 5x3, the r's went over 23K, and the air blast was stirring up grass 30 ft away. Big difference.
Now that's just a pretty plane, no matter how you look at it. Let us know how it flies.
--Ray
Thanks for the compliments friends,
I have APC 5.7 x 3 and 6 x 3 and Master 6 x 3
Starting with 38' lines
The finish is mostly Solarfilm with small amount of paint
around the engine & tank area
will post more next month , when flown , hopefully still
in one piece!!
Vincent
Vince,
Sent you an e-mail.
Roger
Many thanks Roger
unfortunately I wont get to read that until
Friday night, different puters, office n home
then Saturday morn 04:30 away on holiday
for 8 days
appreciate your attention
will reply direct when I get to it
Vincent
