  • June 15, 2025, 09:29:43 PM
Author Topic: McCoy, Testers, Wen-Mac .049 needle valve Where can you get them  (Read 2670 times)
Offline propjobbill
Where can a person get needle valve asemblies to fit these .049 engines. I have several engines with broken needles. Is it possible to get needle valve assemblies to fit these .049 engines. I'm even willing to use other manufactures needle valves if I can find some that will fit.
I'm sure someone here has found a way to fix these broken needles. Can you tell me how to do it.
THANKS
Offline propjobbill
Re: McCoy, Testers, Wen-Mac .049 needle valve Where can you get them
« Reply #1 on: January 08, 2008, 11:27:04 AM »
No need to answer now, I have learned that I can make my own from 1/72 machine screws
Offline Bill Heher
  • Fix-it
« Reply #2 on: January 28, 2008, 09:52:01 PM »
I have used the stock Cox N/V assy from the product motors with the plastic back; in the McCoy/Testors. I can't remember if it was a straight swap- or you might have to drill the venturi out a smidge to get the spraybar to fit in.
Bill Heher
If it's broke Fix-it
Offline jamtx
« Reply #3 on: January 29, 2008, 08:18:39 AM »
Look here...this might help you.
http://www.texastimers.com/
James Karnes
Abilene,TX.
