Guys,
Been working through a problem with consistent engine run upright - inverted and through maneuvers. The engine is an OS baffled 25, side mount on a Ringmaster. I've been flying this ship for 20 yrs, it has had four different motors. First was the old Fox 35, then an OS F20, PAW 15 and finally the current OS25. The OS 25 was a good compromise of weight and power.
A few months ago things started to get inconsistent going to the inverted portion of maneuvers. I started to move the tank and things kept getting worst. Finally, after several searches found a hint that one of the symptoms of a plug going bad was the engine going rich inverted. After changing the plug and getting tank back to the original position all came back to consistent running.
Best, DennisT
