Finished the Micro Ringmaster Stunter, which was built from a kit by Pat King, and uses a Cox Tee Dee .010 engine. (Pat King's webpage is
http://pdkllc.com/airplanes)
It took me a while to figure out how to mount the engine. The cylinder needs to be horizontal to clear the fuselage. Then the outboard mounting screw lines up behind the cylinder. On the outboard side, the screw head needed to be aft of the engine mount, so the tank could fit up close (I had already installed the tank positioning rails). I couldn't find a find a 2-56 nut having a diameter that would fit into the space allowed for it on the forward surface of the red plastic engine backplate. I ended up buying a 2-56 threaded spacer that would fit, and cut it in half. Those became the two nuts. On the inboard side, the nut is aft of the engine mount. There is a hook above and below the fuel tank. Magnet wire was wrapped to secure the tank within the positioning rails, and some drops of Sigment to secure the wire.
Haven't had a chance to fly it yet.
