Frank,
I had one with the Cub 14, we used an 8x5 PowerProp about 2 oz uniflow, fly it on 0.012"cable ~ 52 -54' C to C. If you run it in a rich 2 cycle it will due fine, also could use the Cub 19 (clip 9x5 down to 8.5" prop) on 58 - 60' same diameter lines. Only drawback is not having a muffler, if you are out were noise is not an issue no problem.
Best, DennisT
