General control line discussion => Open Forum => Topic started by: frank mccune on April 23, 2015, 08:35:10 AM
Hi All:
Which would be better to power a Ringmaster Jr? What size and length of lines should be used?
Tia,
Frank McCune
All of the Cub engines were on the anemic side of the power curve. Use the 19 with a 2 oz tank. it will provide decent sport flying performance. It has one advantage it is a light piece of metal.
Dennis
I had a Cub .149 on a PDQ baby clown. It barely had enough power to power it and it liked to catch fire on starting. It was almost worn out.
Frank,
I had one with the Cub 14, we used an 8x5 PowerProp about 2 oz uniflow, fly it on 0.012"cable ~ 52 -54' C to C. If you run it in a rich 2 cycle it will due fine, also could use the Cub 19 (clip 9x5 down to 8.5" prop) on 58 - 60' same diameter lines. Only drawback is not having a muffler, if you are out were noise is not an issue no problem.
Best, DennisT
my first big plane was a guillow's trainer #2 with a green head K&B 15 and would out run the two guys with Cub 19's .next plane was a R/M jr with the 15,on 60 ft lines i did my first loops with it ,i am sure it would have flown better on about 55 ft i would go with the 19.
Bob, If you mean trainer #3 then that was my first plane also, with a K&B Greenhead 15 ! Talk about a tough plane. On the day of my first successful flight, I stuck it straight in the ground 4 or 5 times overcontrolling it!
I would say the 19 also.
The 14 would be cool if you get a set of plans from Pat King for his RM junior plane and build it light. I got the plans from him and plan on using a Cox 09.
LOL. First successful CL flight (c.1954) was on a Ringmaster Jr./OK Cub .14 on 35' lines. Very docile, to be sure, but it did the job. Second Ring' Jr., also Cub .14 powered, was much lighter, hand-launched (no landing gear), and would loop and do mild Figure Eights. Prop was a Tornado Plastikote 7-6 on both. Francisco Powermist fuel.
Ahh....memories!
After beating hollow logs to death with an OK Cub .049, I built a Jr. Ring with a Fox .15x slant plug. I learned to fly inverted on it and also learned how to repair crash damage almost every time I flew it. Somewhere in there I had a trainer of some kind with an OK Cub .19 although I don't think I ever flew it. I still have OK .19. I gave away the Fox 15x last year.
In 1955 I learned to fly the AMA stunt pattern on a Ringmaster Jr, with Cub .14 for power. On 52 ft lines it was actually a good combination. It was a very light airplane and the Cub had plenty of power on .012 52 ft lines (center to center). I was primarily a combat flier prior to that (and after for that matter), but had seen a couple of guys in our club fly stunt and it interested me. The "Ring" Jr was a pretty good flying airplane with that light engine. It was capable of the complete pattern and eventually I learned to fly a respectable (at least recognizable) pattern with it, then built my first Nobler when the "Green Box" kit first came out.
I do remember that the Cub was a little hard to start but ran very well in a wet two! 8-5 Top Flite prop (I think).
My first "gasoline model airplane motor" was an OK Cub 14. It "propelled" my Guillow's Trixter Trainer, then a Jr. Ringmaster, and finally, a Sterling P-40. Always over-propped with a TopFlite 8x6 and under-nitroed with Testor's 39. Looks like I was in good company.... :)
dale g
To get back to the question, the Cub 19 would be a better choice, in my opinion.
Frank, with all this input I'm looking forward to your flight reports. Oddly, I never flew a CL model with any Cub, I used them for FF. My FireBaby had Royal Spitfire and my brother's a Wasp. I did consider using an OK .35 at one point but after the bench run I decided NO ONE should be subjected to that noise!!!!
