  • April 26, 2024, 09:56:01 PM
Author Topic: Enya 53 -4C setup for Rear Exhaust  (Read 2337 times)
Offline Martin Quartim
    • StuntHobby
« on: January 13, 2011, 11:55:13 AM »
The OS 56FSa  90o Elbow fits perfectly with the Enya 53-4c for a in cowl rear exhaust.
Planing to use it with a Pat Johnston SpitFire Mk XIV 626 in the future.
Total weight in this configuration 430g - 15.2Oz
Martin
Offline Mike Wada
  • ACE
Re: Enya 53 -4C setup for Rear Exhaust
« Reply #1 on: January 13, 2011, 04:31:55 PM »
Aloha Martin,
This is very good information!  Thank you for this post, will use with my Enya 53 on next project.
Mike Wada:)
Mike Wada
AMA 512393
    • StuntHobby
« Reply #2 on: January 13, 2011, 08:17:43 PM »
Aloha Mike!
A feature I will try with this engine is to run it in reverse using a pusher prop. I have to thank that info to Bob Zambelli who point it out how easy it is to setup the Enya 53-4C for reverse rotation.
JXF has a  13x6  pusher prop that should work dandy. I have been using the JXF for electric,  they are stronger then regular Top Flite Power point, so I am not one bit afraid of using them. Most of my friends down here are also using the JXF E props.
These are the links for the electric and regular JXF 13x6 Pusher props.
http://www.himodel.com/plane/JXF_13x6_inch_Beechwood_Propeller_for_Electric_Airpalne_Counter_Rotating.html
http://www.himodel.com/plane/JXF_15x6_inch_Beechwood_Propeller_Counter_Rotating.html
Martin
    • StuntHobby
« Reply #3 on: January 21, 2011, 11:37:16 AM »
Just for reference, here are some shots of the engine mounted on the SV-11 ARF.  The Enya 53 is so compact that it fits completely inside the cowl. The engine is not seated all the way in because the mounts are a bit narrow on the SV-11 and there is about 1/16  to go.
Martin
