  • July 30, 2025, 10:37:07 AM
Author Topic: Special controls or uses of U/Tronics Control units  (Read 34687 times)
Offline Clancy Arnold
« on: June 28, 2011, 04:16:43 PM »
I will post in this section unusual or special function that can be implimented when using U/Tronics Control units.
Add low idle speed adjustment and Kill Switch.
Clancy Arnold
U/Tronics Control
Offline Jim Fruit
Re: Special controls or uses of U/Tronics Control units
« Reply #1 on: July 06, 2011, 07:07:00 PM »
Clancy
Now comes the stupid question. When using your system along with one of the slide pots that you provide on a full on/off mode (flaps, throttle, etc.), what position on the servo does full off on the slide pot represent? (My God, that is 36 words in one sentence). As you can tell, I am struggling with what I am trying to say. I just bought a servo driver. I am going to use it to properly set the servos in my next plane. One of it's functions is to find the "center" of the servo sweep. It also can, of course, run the servo from one stop to another. When I set your slide pot to off, what will the position of the related servo be? Will it be all the way to one stop, or will it be centered? I know, plug it in and find out. But I am in the design stage now and the correct answer might help me make some decisions while it is just on paper. Thanks for your help as always.
Jim Fruit
« Reply #2 on: July 06, 2011, 08:32:34 PM »
Jim
The Slide pot or a rotary pot will move the servo from near one limit to near the other limit.  The same thing happens with a switch controlled function.  The servo will move from one end to the other.  The center of the range of adjustment of the pot will be approximately the center of the servo travel.
Clancy
Clancy Arnold
U/Tronics Control
Offline Jim Fruit
« Reply #3 on: July 06, 2011, 08:47:05 PM »
Thank you sir!
JHF
« Reply #4 on: July 07, 2011, 07:57:13 PM »
Jim
You don't SIR an Airman First Class.  LOL
Now it is different with my oldest son, They Call him "Sir" or "Colonel" because he is a Lieutenant Colonel in the IL Air National Guard.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #5 on: July 22, 2011, 04:50:10 PM »
How to connect one U/Tronics Control unit output to two ESC's:
Note that in the attached drawing the power for the Decoder is provided by the lower (# 1) ESC.
Clancy
Clancy Arnold
U/Tronics Control
« Reply #6 on: July 23, 2011, 09:31:14 AM »
A suggested safety switch for dual engine models.
It prevents ground loops on takeoff.
The voice of experience!  (1983 NATS)
Clancy
Clancy Arnold
U/Tronics Control
« Reply #7 on: July 23, 2011, 11:56:38 AM »
An alternative would be a lever that ties the throttle arms together until you mechanically disengage it.  That way you don't have a 'bump' in the throttle setting of the 'off' engine when you flip the switch.
Kinda like how tractor steering brakes work, for those of you who've driven with them.
« Reply #8 on: November 04, 2011, 05:56:03 PM »
After a discussion of the effect of the Throttle End Points on the operation of Electronic Speed Control (ESC) for electric powered models the attached circuit changes were recommended.
I have also included how to add an Engine Kill Switch for I.C. Engines only.
Clancy
« Last Edit: November 07, 2011, 05:14:45 PM by Clancy Arnold »
Clancy Arnold
U/Tronics Control
