  • June 17, 2025, 03:56:48 PM
Author Topic: Newest product - leadout guide  (Read 14894 times)
Offline SteveMoon
    • www.ultrahobbyproducts.com
« on: August 24, 2011, 06:52:43 AM »
We've just introduced another new product here at UHP; a CNC cut leadout guide.
This leadout guide is intended for use with our line of foam wing CL Stunt/Sport/
WWII Combat planes. The guide is made from CNC cut 1/8 ply. To use simply cut
a slot near the tip of the wing, imbed the guide in the slot and epoxy into place.
The guide cut also be cut into several smaller pieces for use in foam wing combat
planes. At only $3.00 each this is an economical time saver.
Later, Steve
