  • June 16, 2025, 08:51:22 PM
Author Topic: VECO Chief II Classic Legal/N-30 Legal  (Read 8182 times)
Offline Jim Catevenis
« on: June 12, 2020, 04:51:46 AM »
                                                            VECO CHIEF II  Classic Legal/N-30 Legal
     Tom Dixon announces the availability of a modernized version of the classic VECO Chief, designed by Joe Wagner.  This kit keeps all of the original dimensions but has simplified, stronger construction, aluminum landing gear, and room for 4 1/2 ounces of fuel.  Wood sizes are upgraded for strength and better balance with a modern .40 size engine.  A copy of Wagner’s own plan for his two versions is included, along with the revised plan.  All contest balsa is cut to shape.
     The Chief has a constant chord wing so it can be built on a flat surface without a jig being necessary.  (This is a balsa wing, not a foam wing, though we do have a foam wing available too.)
Specifications
Wingspan: 53 Inches
Wing Area: 598 Square Inches
Perfect for modern .29 to .40 plain bearing stunt engines.
You provide your favorite control system hardware.
Kit price is $175.00, plus actual shipping cost.
For additional information or to order the new Chief II contact:
Tom Dixon
Controline Sales, LLC
315 Santa Anita Ave
Woodstock GA 30189
Phone: (770) 592-3279
