CLICK HERE--><--CLICK HERE
C/L Timer V7 – Timer and Jeti SPIN set up from your phone
Started by Rogerio Fiorotti, October 03, 2026, 12:58:17 PM
Previous topic - Next topic
0 Members and 1 Guest are viewing this topic.
Rogerio Fiorotti
Fiorotti C/L Timer V7
Preview: still in testing, not for sale yet
Hello friends,
For the past months I have been working on a new version of my timer, the C/L Timer V7. It is not for sale yet, it is still in testing, but I would like to show you what it will be and hear your opinion.
Many of the new features came straight from your posts here over the last years. Thank you all, especially Fred Underwood and Ken Culbertson, for sharing so much experience in the Fiorotti Timer thread.
What is new
  • Everything from your phone, no JetiBox. The timer creates its own Wi-Fi network. Connect your phone or computer and the familiar 16x2 screen with the four arrows appears in the browser. No app to install.
  • Set up your Jeti SPIN ESC through the timer. On the RPM screen there is an ESC button: one tap and the timer connects to the SPIN, and you get the full SPIN menu on your phone – controller type, temperature protection, brake, operation mode, motor poles, gear ratio, rotor RPM, governor sensitivity, timing, acceleration, PWM frequency, number of cells and battery cut-off, and more. No more unplugging the ESC from the timer, no more swapping cables or plugging the JetiBox in and out at the field. It works for the second ESC of a twin too.
  • Safety lock. When a phone connects, the menu is locked ("PRESS START TO CONFIGURE"). One tap on the timer button unlocks it, so only the person holding the model can change settings. Wi-Fi is off during the flight, and the flight only starts from the timer button.
  • Flight Logger. Every flight is recorded, 15 samples per second: acceleration on 3 axes, ESC command and governor correction, plus all the settings used in that flight. See the graphs on your phone right after landing and save the file.
  • 3D-Cal. Sensor calibration in 6 positions (level, inverted, outboard wing down and up, nose down and up). The timer finds the sensor orientation by itself, and at the end it shows 1.00 g in any position to confirm the calibration.
  • Separate brake and boost. Independent Decrease and Increase gains, for acceleration along the flight path (Linear) and for line tension (Centripetal).
  • G-Force with Decrease and Increase, an attack curve with a G limit, and a built-in calculator: enter line radius, lap time and model weight to get the target G and the line pull.
  • Corner Booster. A short RPM boost at the exit of the bottom corners, where the model slows down and the governor is late.
  • New: Vibration check. The timer records the vibration peak of every flight and shows it on a bar. Up to the middle mark the vibration is acceptable; beyond it, the prop, spinner or motor mount needs attention (balance or better isolation). The middle mark is adjustable. A simple way to catch an unbalanced or damaged prop before it shakes the model, since too much vibration is also bad for the sensor readings.
  • New: Start Ramp. A soft start: the motor rises smoothly from zero to the flight RPM in a time you choose, up to 5 seconds in 0.1 s steps, instead of jumping to full power. A gentle takeoff, with less torque kick and less stress on the prop, motor and battery. Off by default.
  • Firmware updates over Wi-Fi. No need to send the timer to Brazil. Your settings are kept.
  • Small and light. Timer board 20 x 26 mm (0.8 x 1.0 in) and sensor board 17 x 32 mm (0.7 x 1.3 in), 14 g (0.5 oz) together.
  • Also: Nose Up with adjustable angles, automatic overhead protection, external LED with signalling modes, second motor with RPM offset, retractable landing gear and Safety Gear (the gear goes down if G stays low, as in an engine failure).
Pictures below: the Jeti SPIN set up through the timer, some of the timer screens, and the Flight Logger.
Price and availability are not defined yet. I will post here when it is ready.
What would you like to see in a new timer? Is there anything you miss in your current setup? Your comments are very welcome.
Rogerio Fiorotti
rogerio@cltimer.com
Like Like x 1 Agree Agree x 1 View List
